Nissan Micra Engine Transplant
701 replies to this topic
#631 l_jonez
l_jonez
  • 1,453 posts
Posted 01 May 2011 - 07:44 PM
Here's an idea I had a while back, there's something similar on eBay atm
http://cgi.ebay.co.u...=item3a65a2cec0
Listing is nothing to do with me but it is a pretty good idea.
#632 l_jonez
l_jonez
  • 1,453 posts
Posted 02 May 2011 - 07:45 PM
Was playing with manifolds earlier and found that an hif44 would fit onto a Toyota manifold with out to much work.
#633 James_1
James_1
  • 253 posts
Posted 16 May 2011 - 05:00 PM
I've potentially found a "complete" 1.3 engine and 1.0 gearbox with gear linkages and drive shafts from a breakers at a good price. BUT it doesn't have an ECU or wiring, is it even worth considering without? Does anyone know if the wiring for the 1.0 is different to the 1.3, ie could i get a 1.0 loom and use that with a 1.3 ECU?
James
#634 garethleesmith
garethleesmith
  • 313 posts
Posted 16 May 2011 - 05:18 PM
James
Hi mate i have a nissan micra 1.3 gx on a 1996 (p) For the car as a whole you can have it for £220 comes complete with engine gearbox ecu everything you want plus a micra car you can scrap! Thanks - pm me if your intrested!!
#635 James_1
James_1
  • 253 posts
Posted 16 May 2011 - 07:56 PM
PM sent :D
#636 whyter
whyter
  • 34 posts
  • Local Club: IMOC
Posted 17 May 2011 - 06:35 AM
Hi guys
With relation to swopping the 1.3 gearbox for the 1litre gearbox on a 1.3 k11 engine, has anyone done it before. The flywheel, cutch ect are completly different, is it ok to put a 1l flywheel clutch assembly onto a 1.3 engine. are there any issues regarding balance of the crank ect
Thanks in advance, we re bring this thing to IMM in 3 weeks could have done without this problem
cheers
joe
#637 Artstu
Artstu
  • 829 posts
Posted 17 May 2011 - 07:27 AM
Frank on the Micra forum runs 1.3 engines on 1.0 boxes with the small clutch and flywheel. I also think he tinkers with hybrid home modded 1.0 clutches with 1.3 friction plates. He finds the small clutch will take the power from a 1.3 without much trouble.
post 66 http://www.micra.org...ght=#post455596
Edited by Artstu, 17 May 2011 - 07:47 AM.
#638 James_1
James_1
  • 253 posts
Posted 17 May 2011 - 08:30 PM
After looking at the gear ratios of the 1.0 box I've decided to drop the idea. It's going to have to be a 1.3.
#639 Artstu
Artstu
  • 829 posts
Posted 17 May 2011 - 08:43 PM
Wise choice, any Mini needs as high a ratio as possible, and the 1.3 box is pretty good for that, I can't open that attachment.
#640 James_1
James_1
  • 253 posts
Posted 17 May 2011 - 08:59 PM
Strange, I've just tried the attachment and it's fine for me :s
#641 evansisgreat
evansisgreat
  • 1,100 posts
  • Local Club: Not yet
Posted 18 May 2011 - 11:26 AM
Opens fine for me. Good call on the 'box, it'll make the car much more usable I think.
#642 James_1
James_1
  • 253 posts
Posted 19 May 2011 - 06:16 PM
I've bitten the bullet and I'm picking up a 1.3 engine, gearbox, wiring and driveshafts at the weekend...
#643 evansisgreat
evansisgreat
  • 1,100 posts
Posted 20 May 2011 - 03:00 PM
Nice one mate, good to have another one on the go! Are you going to make a tmf thread or continue on your blog? Or both?
#644 James_1
James_1
  • 253 posts
Posted 20 May 2011 - 10:39 PM
I'm going to do a thread here for the conversion part and have the blog covering the entire build - the build doesn't really fit into an area here - it's both a complete build and a conversion! :P
I'm picking up the engine in the morning...
#645 l_jonez
l_jonez
  • 1,453 posts
Posted 31 May 2011 - 10:05 PM
I picked this up today
Expect a build diary soon
