Nissan Micra Engine Transplant
#541
Posted 21 June 2010 - 11:44 PM
#542
Posted 21 June 2010 - 11:55 PM
i must share with you our latest installation.
this car belongs to proud TMF member, minidude1000
it is an actual upgrade on his MA10 engine which has gone strong for the last three years.
he has chosen to stay 1000cc. (maybe he doesn't want to change his screen name, lol) going with the 16valve CG10.
he has had the manifold made using that of his last engine as well as the dizzy.
as usual here are some teaser shots as my friend has not yet seen the final install either:
Edited by bigchief3679, 21 June 2010 - 11:56 PM.
#543
Posted 22 June 2010 - 07:32 AM
I know that you usually place them above the head on the left hand side, but what do you use to deflect the belt around the 'camshaft buldge' that can be seen in the pictures, i think if i do this without an idler pulley of similar the belt will just rub on this! What do you guys use?
thanks
#544
Posted 22 June 2010 - 09:55 AM
As you can see he's added a small idler pulley on a slotted bar. Easy peasy.
#545
Posted 22 June 2010 - 10:00 AM
does anyone know where i can acquire such a small idler pulley tho?
thanks
#546
Posted 22 June 2010 - 10:05 AM
#547
Posted 22 June 2010 - 10:10 AM
tah
#548
Posted 22 June 2010 - 11:58 AM
#549
Posted 22 June 2010 - 06:51 PM
Does anyone have the lengths of the driveshafts for the 1L CG10 engine conversion with the small 1L 5 speed gearbox.
With Ian's help I have a fellow 16v forum member who will fabricate a set for me if I supply the raw materials - 4 driveshafts which I have but I need the lengths.
Can anyone help me ?
Andrew
Edited by apjmini, 22 June 2010 - 06:51 PM.
#550
Posted 22 June 2010 - 08:09 PM
I can tell you my driveshaft lengths although i doubt they will be of any use to you since the engine position and size is probably different!
I would seriously suggest measuring them yourself as no 2 conversions are going to be the same.
If you require help with measuring give me a shout and ill tell you the method i used!
IAn
#551
Posted 23 June 2010 - 07:26 PM
ok..........well you guys got me excited once again.
Yeah, thanks bro! show everyone in the world except me!
Guys, this is gonna be fun!
#552
Posted 24 June 2010 - 10:31 PM
well then i hope you like these that we took along the way......
and some finished shots of the engine bay.
its ironic that the carb'd version looks as if it were injected............while the injected ones are sworn as being carb'd
wait till you guys see what's next.........
#553
Posted 24 June 2010 - 11:01 PM
#554
Posted 24 June 2010 - 11:50 PM
v nice as usual bg chief, mine is really underway now. My mini now have 5 slectable gears (and reverse!)
i know that feeling, its great! and i've been there about 23 times so far..........
#555
Posted 13 July 2010 - 10:01 PM
This is the frame i am doing for a customer very similar to yours! this has been in the car a few times and we have had to move the engine very slightly from our first positioning, this will be back with the customer for the next two weeks, then i hope we can have it back for final finishing. Might even make a few more frames while we are at it if there is enough interest
This first one was in the making after first time with the customer
The ones below are how it has gone back out tonight
Edited by ringonezero, 13 July 2010 - 10:03 PM.
