Nissan Micra Engine Transplant
#286
Posted 03 February 2010 - 10:02 PM
any ideas? thanks
#287
Posted 03 February 2010 - 10:07 PM
also wondering if anyone has gearbox numbers or anything printed on their gearboxs, or an easy way to tell (a measurement?), would like to see how cheaply i could get a 1L smaller box but don't wanan accidently get another the same!
any ideas? thanks
Make sure it's sitting in a K10 Micra and has 5 gears on the gear-knob
#288
Posted 03 February 2010 - 10:11 PM
any ideas? thanks
i believe some of the earlier k11 had them though?
just wanted a way to be sure if i see one on ebay or anything, then i can message the seller! thanks
#289
Posted 04 February 2010 - 09:46 AM
Later 1.0L K11's shared the same bigger shafts and CV's of the 1.3L one, with a lower final drive ratio.
#290
Posted 04 February 2010 - 12:11 PM
I'm not sure sorry. I do know that early 1.0L K11's used smaller CV's and driveshafts compared to the 1.3's but I have a feeling the box was the same size.
hmm interesting, any one else know anything about this?
cheers plastic!
#291
Posted 05 February 2010 - 12:58 AM
cheers plastic!
yes its true......the smaller box on cg engines is exactly the same internally as the k10 5 speed, but alot smaller than post 98 cg10/13 boxes. the only difference visually are webbings on the outside and the GB mount holes are different.
here is a photo of the K10 and small K11 boxes side by side:
Edited by bigchief3679, 05 February 2010 - 01:02 AM.
#292
Posted 05 February 2010 - 01:40 AM
was also wondering fuel tank wise? what do you guys use?
thanks
#293
Posted 05 February 2010 - 09:58 AM
The early K11 box still looks bigger than the box bigchief has on that engine he is about to lower in, confusing to say the least.........
#294
Posted 05 February 2010 - 02:09 PM
Post 538 on here could help http://www.micra.org...nk-s-k11/page11
i think most of big cheifs use the early k11 box that they seem to do on the 1.3's they get (jap spec model)...but i am not fully sure on this!
still wondering how people plan on doing the fuel tank?
#295
Posted 05 February 2010 - 02:25 PM
MPI Mini would be the easiest way. Or fit the Micra fuel pump in the mini tank.
#296
Posted 05 February 2010 - 02:28 PM
#297
Posted 05 February 2010 - 02:38 PM
You could use an external fuel pump and a swirl pot.
#298
Posted 05 February 2010 - 02:40 PM
#299
Posted 05 February 2010 - 04:35 PM
hmm i see, just out of interest why is the return line needed?
You need a return as the injectors need a very high and constant fuel pressure, this is easiest to arrange as in the following diagram.
Carbs use low pressure and the pump is low pressure and just fills up the carb reservoir until it's blocked off by the float.
#300
Posted 05 February 2010 - 05:02 PM
thanks for the advice! what would you reccommend then?hmm i see, just out of interest why is the return line needed?
