Nissan Micra Engine Transplant
701 replies to this topic
#226 bigchief3679
bigchief3679
  • 228 posts
  • Local Club: trinimini
Posted 03 October 2009 - 03:52 PM
thanks, thats answered all of my questions, i think im going for a nice cheap low milage cg10, and proably going to cut the whole in the bulkhead, it looks alot smaller than the MA10 as you said. now all i need to do is get the parts together :(
oh i take it i can use the mpi fuel pump to feed this so thats another thing not to worry about
yeah, i guess the mpi pum should be ok. how much psi/flowrate is it capable of? the bulkhead mod is more like a dent to be honest.
#227 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 03 October 2009 - 04:19 PM
the flow rate should be fine judgeing by how much petrol it likes to consume. i belive im running 2.7 - 3 bar on the injectors at the moment. which is psi if you times it by fifteen, i think 45psi
#228 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 05 October 2009 - 01:40 AM
I was wondering if anyone on here would reccomned insurance companies that will insure me on a mini with a micra lump, and also would i need to get the car checked by someone for safety etc... i know nothing about these two things!
cheers
#229 Artstu
Artstu
  • 837 posts
Posted 05 October 2009 - 10:08 AM
has anyone tried taking the mesh out, from over the throttle body on the k11 micra manifold?
It was you who asked this! I'd forgotten. I removed mine after this and feel as though I've gained 5hp!, got loads of stick on the Micra forum for sharing this tip, all negative I might add.
If you're after insurance does that mean you have completed a Micra conversion then?
#230 leaky
leaky
  • 6,890 posts
Posted 05 October 2009 - 11:44 AM
Sorry if this is a dumb question. Do you need to put an extended front on the mini to do this or does it just pop in so to speak?
#231 bigchief3679
bigchief3679
  • 228 posts
Posted 05 October 2009 - 12:18 PM
just pop it in bro!
(after modding ur sub and indenting your firewall)
#232 oli
oli
  • 128 posts
Posted 05 October 2009 - 12:40 PM
Bigchief,
Your my hero I love what you do with minis. Your so resourceful, I bet most things are hard to find in Trinidad and Tobago. If I ever get to Trinidad/Tobago I'll find your mini club. Keep up the good work.
Oli
#233 flying banana
flying banana
  • 84 posts
Posted 05 October 2009 - 05:12 PM
hi all
engine fits lovely in frame now. i had to make some eng/mtg's brackets,
now how do you connect up and use the clutch/pedal end what sort of brackets
did you have to make up any pics please.
Ive taken my electronic speedo drive out and want to use my mini speedo head
is it poss to replace the electronic one with an older one so as to use old speedo
and to convert to mechanical and not electronic
thanks andy
#234 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 05 October 2009 - 11:18 PM
Took my mesh out of the throttle body after seeing your post bigchief , wow it makes a big difference, much more responsive and pulls a lot better too :thumbsup:
thats my tip! dont i get the credit?
#235 Artstu
Artstu
  • 837 posts
Posted 06 October 2009 - 07:33 AM
Yes you do, see above! or put another way you're responsible all the grief I got on the Micra forum :thumbsup:
Edited by Plastic rules, 06 October 2009 - 07:34 AM.
#236 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 06 October 2009 - 11:19 AM
negative how? you might get dirt in the engnine if your a moron? after i did it to my micra i could keep up with a zetec S :P
Edited by bigmotherwhale, 06 October 2009 - 11:22 AM.
#237 Artstu
Artstu
  • 837 posts
Posted 06 October 2009 - 11:30 AM
I was that annoyed I wiped most of my posts
http://www.micra.org...ead.php?t=33566
More here
http://www.micra.com...messageid=49109
and more in this thread
http://www.micra.com...messageid=49265
#238 bigchief3679
bigchief3679
  • 228 posts
Posted 08 October 2009 - 10:28 PM
Bigchief,
Oli
thanks Oli. its comments like yours that make may brother and i very proud of what we do.
PS ur welcome any time to make a trip with TRINIMINI whenever u get to T&T.
#239 bigchief3679
bigchief3679
  • 228 posts
Posted 08 October 2009 - 10:50 PM
hi all
thanks andy
i've got no pics of the pedal ,sorry but its really quite simple. the most important calculation is the distance off-centre of the cable attachment to the pedal. this determines whether ur clutch will be hard or soft and ours are usually drilled at 1.5 inches from the pedal-bushing centre. basically the pedal pulls on the cable head from behind.
#240 bigmotherwhale
bigmotherwhale
  • 301 posts
Posted 09 October 2009 - 12:50 PM
dont worry what people say plastic, there always going to be negative in some respects. we both know how fast they go without the mesh and its not just imagination, vizzard has done tests on mesh and tights ect on a mini and the performance is not good. how many times have you looked at your mini and went i think i need more stuff in the way of the airflow. or i need a mesh in there incase my airflilter (which has a mesh on the outside) explodes.
and as for the maf sensor i think thres a better way to provide turbulent flow than a mesh. if yoou ask me it was put there becuse the micra engnine is incredibly powerfull and it would have had to be in a different insurance band if it were any more powerfull, and this is quite a good way of restricting power.
    Bing (1)
