Tpi Code Reader Software And Obd Cable Question
3 replies to this topic
#1 MrOz
MrOz
  • 35 posts
Posted 06 September 2007 - 08:21 PM
I was wondering anybody would know if this software from eBay would be any good for the TPI?
Clicky
And what type of OBD cable I would need and any idea where I could get one?
Oz
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 06 September 2007 - 09:33 PM
The Mini is not OBDI or OBDII, it was Rovers own interm version of OBD. The OBD connector is the same, but its wired differently.
You need something like the Sykes and Pickavant ACR4 with the Rover V2 or higher aplication pod, and the specific rover cable.
#3 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 07 September 2007 - 04:37 PM
An ACR2 or ACR4 will work, but I believe you need the Sykes Rover Pod version 3 for TPi. The version 2 pod may work for Spi, but I am not sure. The current version is 4, but some people have indicated that they have trouble working with Minis with version 4.
There was an issue with some of the cables working better with Minis also, but hopefully that is sorted out now.
Sykes Pickavant Support Forum
I stand corrected as this was posted on the SP forum:
>With the 2 Rover Pods that you have the following systems are covered.
>Rover 1 Pod
>E.R.I.C
>SPI non-cat
>SPI Cat
>Rover 2 Pod
>Standard MPI
>Sequential MPI
>Montego 2.0l MPI
>These only cover the K Series engine fitted with a Mems 1.6 Systems.
So Rover Pod 1 will cover some SPi, possibly Mini. The Rover 2 Pod does not cover the Mini TPi using the MEMS2J ECU.
Sorry to add to the confusion
Edited by tmsmini, 07 September 2007 - 05:02 PM.
#4 MrOz
MrOz
  • 35 posts
Posted 07 September 2007 - 06:09 PM
Cheers for the replies. At least I know what I'm looking for now.
Thanx
