R1 engined RWD Mini Pickup
301 replies to this topic
#136 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 15 September 2005 - 01:13 PM
No, I didn't mention it to Chris.
Most of the movement was necessary due to the lowering of the front end, and my obsession with suspension travel. I just wasn't happy with the setup out of the box.
I didn't want to compromise on the rear ride height in order to get the car running level (i.e. parallel to the ground), so rather than winding the rear up, I lowered the front instead. I can now run the car slightly nose down if required, but like I said it really just increases my options.
I got my kit in October last year I think, so there may have been some changes since then, but realistically I dont think my setup would be offered off the shelf due to the changes needed to the front subframe to allow a decent travel. Most people wouldn't be willing to re-model their subframes.
I just thought "Why have some decent coil-overs, and only use 50% of their travel potential, and be forced to run them hard, or put up with knocks and bangs?"
I may end up binning the lot yet!.... but not before I've got the present one done, and tried out. I can always move on once I've got a benchmark.
#137 pete
pete
  • 680 posts
Posted 21 September 2005 - 06:50 PM
Sorted my knocking noises. Took Dale's advice and drilled new holes in the bottom shock mounts and welded up the old ones. Took it down the road and all seems ok. Also mounted my speed sensor onto one of the front cv joints. Just got to work out how to set up the gauge.
Only problem now is that the oil pressure sender unit decided to let go of the engine whilst at full revs in 4th :sad: . Only realised the problem when lots of smoke started pouring out the back. :) Got out to find the engine had emptied all it's oil over the road. Hopefully no damage done but got to get some more oil and fix the sender unit in properly before I know for definite.
#138 R1minimagic
R1minimagic
  • 4,660 posts
Posted 22 September 2005 - 06:07 PM
Full revs in 4th.....that would be about 100mph??? :) :)
#139 pete
pete
  • 680 posts
Posted 22 September 2005 - 07:55 PM
Haven't got a clue what speed it was cause speedo's not set up yet. Was damn quick though. Narrow country roads always makes it feel quicker.
Good news is it appears no damage done. Only lost about 2lt of oil so still had some in it :grin: . Fixed my sender unit and will be testing again this weekend. Hopefully with the speedo working.
One question though. What clutch springs are everyone else using. Seemed to slip when I changed up the gears using the clutch. I've got standard clutch assembly with an additional return spring fitted between the clutch arm and slave cylinder. Do I need to add any others or just stop using the clutch for upshifting.
Pete
#140 R1minimagic
R1minimagic
  • 4,660 posts
Posted 22 September 2005 - 08:17 PM
Pete
Mine is fine with the standard setup using a normal mini return spring, definately no slipping..
Maybe u need a new clutch!!
#141 R1minimagic
R1minimagic
  • 4,660 posts
Posted 22 September 2005 - 08:23 PM
One thing to try Pete.
Have you got any free play in your clutch rod?? If not, then the clutch will not be returning properly and will slip. You need about 2mm free play between the end of the clutch rod and the slave piston. Worth a quick check before you pull it apart!
#142 pete
pete
  • 680 posts
Posted 15 October 2005 - 05:30 PM
Pics of it finally finished. Sorted all the little teething problems. Been up and down the road again. Still brings a big smile to my face :grin: :grin: . Won't be putting it on the road untill next year now. Don't want to get it wet :cheese:
#143 pete
pete
  • 680 posts
Posted 15 October 2005 - 05:32 PM
back end
#144 pete
pete
  • 680 posts
side view
#145 pete
pete
  • 680 posts
Posted 15 October 2005 - 05:33 PM
And the best bit :grin:
Edited by pete, 10 December 2006 - 07:07 PM.
#146 Will
Will
  • 1,223 posts
Posted 15 October 2005 - 05:39 PM
Man that looks soooooo cool... can i have a drive :fear:
#147 Ollie180
Ollie180
  • 2,781 posts
  • Local Club: Sasmog.co.uk
Posted 15 October 2005 - 05:55 PM
wow dude it looks amzing how does it feel to drive it? :tongue:
#148 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 15 October 2005 - 06:03 PM
Dunno what to say Pete, it's a work of art mate! I love it! :angry:
I'd still like to know what you are gonna do with the back? maybe a one-off cover?
#149 m3ntalist
m3ntalist
    Ring Runner 2005
  • 924 posts
Posted 15 October 2005 - 06:13 PM
Well done! It looks great :angry:
#150 pete
pete
  • 680 posts
Posted 15 October 2005 - 06:28 PM
The back cover is the winter project. It will have a 2 piece cover. Rear section hinged, opening up electrically. Inset into the cover will be the R1 logo in perspex so you can just get a glimpse of the engine. Bit more checkerplate to finish the top edges and maybe some to form inner wheel arches.
