hehe, to remove the front end of the mini, would possibly require just touching it - it's rotten as buggery! It needs a LOT of bodywork to get it close to usable. But I know what you mean - you also have no idea how much I want to get back in it, and drive him again - I have to walk past him EVERY time I leave the house
But, mods + repairs that are needed to the shell include:
front end chopped off (obviously!)
scuttle replaced
both flitch panels repaired
front+ rear floorpans repaired (or just a new floor panel!)
boot floor + rear arches removed
doors reskinned + bases repaired
sills removed, inner sills repaired, new sill shapes made
Then after that, the front needs to be enclosed, and the bonnet + grille made
The shell is, to be honest, one of the LAST things that needs to be done., as it's mainly a cosmetic part.
The chassis needs to be made,
the rear suspension fitted
front suspension built, aligned, then somehow fitted
steering mechanism needs to be arranged
the engine + gearbox lined-up and fitted
hehe, THEN all the funky bits can be added
But for now, until I get about £100 spare to buy the two lengths of box section, and get them delivered (only bloody supplied in 7.5m lengths!) All I can do really, is just think about the other parts that are needed. I only really have around £30/month spare atm, so really REALLY hoping to get this new job - then I'll be able to get shedloads done in a relatively short amount of time!
Buy box section - get it cut to lengths
Buy ARC welder, to fit it all together!
Buy parts needed to make power supply for my own ARC/TIG/Plasma cutter (yes..no joke. My homemade spotwelder is going to be for the bodywork too)
fit rear diff + suspension
fit front suspension + steering rack (possibly mini)
make engine mounts
fit engine + 'box, take measurements for custom propshaft
Then... after all those have been done, I need to start on the shell! hehe
But, Guru gave me a link to something on fleabay which just made me go "yaaaaaaayyy!"
http://cgi.ebay.co.u...emZ130260294094extend it by around 2-3 foot, and give the bonnet more of an angle where it meets the body (so you dont have that weird flat bit) and a fair bit of jigger-pokery to the backend, and that is pretty much how I want mine to look!
