Lol, if I had some cash, there would indeed be more action!
But... quite glad I didn't just jump into building the chassis, as I'm now starting to learn about suspension angles - it's actually quite a simple subject to get your head around once you read a well-written explanation!
http://www.rqriley.com/suspensn.htmSo, I need my bottom arm to be almost horizontal, if not slightly downwards-pointing (for my needs anyway) the upper arm needs to be pointing upwards - this is from the chassis by the way, this can give me a roll centre halfway between the chassis and the ground.
The upper-arm needs to have the balljoint slightly rearwards in comparison to the bottom arm (for castor)
Slightly tilting the upper-arm will give me anti-dive control under braking conditions (and with the sheer weight of the engine and suspension, I'm going to need all the help I can get!)
Also, I've decided to have the entire front suspension assembely
IN FRONT of the grille, like Jay Leno's Tank car
The two main reasons for this are:
1) I don't have to try to minimize it, to suit a certain "look" that most people think of when they think of a hot-rod
2) this car is more about function over form!
3) I like the mechanical bits on show!!
To accommodate the suspension within the minis' normal width (I want the front wheels' track to be similar to a standard minis') The chassis rails will be brought to within a few inches of each other straight after the grille, but still kept parallel. I'm still considering exactly how to deal with the front suspension - wether it be a single coilover through the centre of the arms, a coilover setup either side of the arms (like the rear suspension) or something different, like the Z-cars front subframe setup, with bell-cranks to allow me to use horizontal coilovers (gas units of course, as hydraulic ones would be useless at anything more than 45 degrees!)
So, until I know exactly what type os suspension units I can use, I'm going to have to leave the front suspension as it is atm!
Oh yeah, decided, 100% going twin engined, and deffo converting the auto 'box, to run as a manual (solonoids to control oil flow to where I want it, ran from switches, including a paddle-shift style setup)
