My V12 Cooper
#166
Posted 05 August 2008 - 08:17 PM
#167
Posted 05 August 2008 - 08:27 PM
#168
Posted 06 August 2008 - 10:22 PM
#169
Posted 07 August 2008 - 08:14 AM
Look at the left hand side, you shouldn't be able to see the spring!!
It's essentially just two A-arms, but with the bottom enclosed in with a plate of steel, which supports the spring. The upper portion then rests inside the subframe.
Not too easy to make out, but at the bottom edge of the brake disc, is the lower arms, holding in the spring, at at the upper edge of the disc, are the upper arms
Here's a picture of the lower arms, with the spring supported, and the lower plate unbolted - you can see the shape I'd be left with if I did remove it:
My thoughts are, fit the arms to the chassis rails (using 3.5mm steel plate) and then possibly use twin coilovers on each side, like the rear end uses - if only because they're quite small!
Quick bodged pic of how the support may look - suspension arms highlighted in blue
Edited by chairchild, 07 August 2008 - 08:16 AM.
#170
Posted 07 August 2008 - 08:34 AM
Edited by Ethel, 07 August 2008 - 08:34 AM.
#171
Posted 07 August 2008 - 09:41 AM
That's the great thing about making my own suspension support towers - I get to choose all the angles and all the positioning of parts, so I can make it exactly how I want!
#172
Posted 07 August 2008 - 09:44 AM
#173
Posted 07 August 2008 - 09:58 PM
hehe, gonna try to mount that "wooden lady" somewhere on the dash of the pug soon as well by the way
#174
Posted 07 August 2008 - 10:03 PM
#175
Posted 08 August 2008 - 01:39 AM
yoinked these pics from another site!
Not bad I think!
#176
Posted 08 August 2008 - 01:38 PM
#177
Posted 08 August 2008 - 04:05 PM
junky tell me what you have on msn because i need some proper thick steel for a bracket to go on my spotlamp barWe may have a bandsaw at some point.. as we are trying to move eventually..Will let you know what junk is going
#178
Posted 08 August 2008 - 07:31 PM
#179
Posted 08 August 2008 - 10:40 PM
http://www.csgnetwork.com/cfmcalc.html
... I'm gonna need carbs of around 560CFM capacity for a 5.3L (at 100% VE) which is odd, as an unmodified HIF44 flows 240cfm - which means that 3 HIF44 carbs would apparently be enough.... But I want something a bit more..... downdraught!
So, something cheap, and readily available, the good old weber 32/36!
It's not very glamourous, but I dont care - as I can easily get 3 of these for next to nothing, mount them in a line down the centre of the engine, and have them working off one control rod
Another good reason for having three carbs... is because I want three! hehe
But apparently the 32/36 webers have a habbit of giving some nasty "stumble" when you snap the throttle shut as standard without LOTS of faffing with the ignition timing - but they're easy enough to modify to sort that (primaries and secondaries all open at the same time - rather than in sequence)
and Nikki, you're a legend! hehe
#180
Posted 09 August 2008 - 12:18 AM
Each carb will feed 4 cylinders (essentially, each one has a 1.7L engine to feed) The whole thing will be made as one piece, from sheet steel and some tubing. Each section will be internally divided, to aid with fuelling accuracy. I may internally sculpt them with epoxy resin to improve airflow, because it would be a damned sight easier than moulding the steel to those sort of shapes!
Will more than likely get the flanges laser-cut by a local company, because at least they'd all be identical!
