Did chris cut the shell for you? Also what is your floor made of ? Not really seen one in the flesh.
Are you happy with it now?
Mark :wales:
Posted 14 November 2005 - 10:47 PM
Posted 14 November 2005 - 10:52 PM
Posted 14 November 2005 - 11:07 PM
Bloody hell, even the floor is fibreglass!!!!!!Yeah Chris cut the shell because they had to build the kit to the car as it's smaller.
The original floor is thick fibreglass but we weren't sure if it'd be strong enough so Chris cut and shaped some chequer plate just to be sure :grin: Looks very nice too!! :grin:
Posted 15 November 2005 - 08:47 AM
Posted 15 November 2005 - 09:29 AM
It has a steel roll over frame that everything was fibreglassed to. It's "so heavy" :tongue: because to get good strength they layer it up thicker. In fairness when we chopped out the box section and before the kit went into the bodyshell the floor didn't sag anything like as much as a normal mini so it must work. :grin:Bloody hell, even the floor is fibreglass!!!!!!Yeah Chris cut the shell because they had to build the kit to the car as it's smaller.
The original floor is thick fibreglass but we weren't sure if it'd be strong enough so Chris cut and shaped some chequer plate just to be sure :grin: Looks very nice too!! :grin:![]()
I thought the body was moulded to a steel floor at least, because that's what your arse is bolted to :fear: :fear:
Why is it so heavy then?
Mark :wales:
Just for the record what did a standard mini weigh roughly???
Posted 15 November 2005 - 09:50 AM
Posted 15 November 2005 - 09:51 AM
Posted 15 November 2005 - 04:27 PM
Posted 15 November 2005 - 04:30 PM
Posted 15 November 2005 - 04:39 PM
:grin: smiles to you too:grin:
Posted 15 November 2005 - 04:40 PM
I only smiled becaus i only kinda kno a lil what you on about and dont wana look dumb:grin: smiles to you too:grin:
DD Yeah I know about the fibreglassing. All the other fibreglassing has been fine. Typically that day I borrowed the stuff from my neighbour who had different resins hardeners and stuff than I'm used to and the mixture% sheet was stuck to one of the pots :nugget: :grin:
So we guessed it and I suspect got it a little wrongI've since got more stuff that I'm used to so hopefully won't have the same problem again :grin:
Posted 15 November 2005 - 04:54 PM
Posted 15 November 2005 - 04:56 PM
Posted 15 November 2005 - 05:04 PM
Posted 15 November 2005 - 05:06 PM
lolIf your small you can this job if you like :grin: It's a leaning through the boot hole and fibreglassing whats above you whilst not leaning on the bodywork kinda job.... Which for the larger gentleman (shut it Jammy!! :tongue: ) is not so easy! :grin:
