1978 Mini Clubman K100 Twinky
miniboo
, Sep 05 2007 05:42 AM
263 replies to this topic
#61
Posted 11 November 2007 - 06:06 PM
yeah should be ok i reckon.
just have to try it and see
#62
Posted 12 November 2007 - 02:22 AM
haha Cowboy, a block heater...necessary. Can carbs be remote started? have fun with your interior heater in the winter mate it's about to get cold soon as well...
#63
Posted 16 November 2007 - 06:37 AM
plans might be changing to a 1275 block as 998 may be a bit involved and with the language barrier i may not get what i want actually done!!
#64
Posted 16 November 2007 - 06:52 AM
but don't they speak English over there ?
or are you in hill billy land
#65
Posted 16 November 2007 - 09:33 AM
Sounds like his local engineer is Cornish....
#66
Posted 16 November 2007 - 11:40 AM
we get about a bit
they say look into the bottom of a hole anywhere in the world and you will find a cornish man
#67
Posted 16 November 2007 - 02:33 PM
no they speak american!! i speak english! believe me there is a difference!!
#68
Posted 16 November 2007 - 07:21 PM
yes. ANd i think "canadian" is closer to english imho. we like england better than the US
#69
Posted 16 November 2007 - 07:22 PM
is that because we are not the neighbours from hell
#70
Posted 16 November 2007 - 11:14 PM
haha pretty much. and you know the war of 1812 'n that we were you etc. etc.
Canada was only formed as a seperate nation in 1867 you see.
history is now over class, your dismissed
#71
Posted 17 November 2007 - 07:41 AM
no gold star
#72
Posted 17 November 2007 - 08:34 AM
history!?
#73
Posted 19 November 2007 - 12:13 AM
well after a good days thinking i am going to press on with the 998 engine. for the cost of buying a 1275 block and crank(and teh postage) i can offset that against the possible extras of using the 998 engine which i already have. i now have a 1275 and a 998 head gasket sio can work out if i need to offset bore(hopefully not) and how big i need to go. hopefully only to +80 or i will have to get pistons from australia.
I might even get some pics up later on.
#74
Posted 19 November 2007 - 05:00 AM
well i have tried the head on again with the cams bolted down and it looks like i will have to pocket the block for the exhaust valves but only on 2 cylinders i think.
i am guessing that i will have to do it on all 4 though to make it even on each cylinder?
should be getting my throttle bodies, injectors and wiring harness through by the end of the week. another ebay bargain!!
as the cam will only be turning the oil pump do i really need to change the cam bearings or will they be ok?
#75
Posted 19 November 2007 - 07:39 AM
i think you should pocket all cylinders or other wise your compression ratio will be different
