1978 Mini Clubman K100 Twinky
miniboo
, Sep 05 2007 05:42 AM
263 replies to this topic
#226
Posted 04 March 2009 - 10:18 PM
May deadline....maybe. would be nice to have it on the road for my 30th borthday.
Being doing more welding today and i am starting to get bored. i havent even started the drivers side sill which is in worse condition than the one i just did. I have been patching the arse end today, rear set and the like. pics to follow
#229
Posted 06 March 2009 - 04:48 PM
lots of worm! keep at it
#231
Posted 13 March 2009 - 02:25 PM
Did a bit of work on the short engine and it is now built. just need to stick teh gearbox on then i can take it off the stand and and add all the ancillaries and the cylinder head.
#232
Posted 13 March 2009 - 02:26 PM
Moving along well now
When you expecting to have it finished by?
#233
Posted 15 March 2009 - 05:01 PM
your guess is as good as mine.....my People carrier has a problem with the engine so will hve to fix that first. probably will be big money!!
#234
Posted 22 April 2009 - 07:09 PM
People carrier was an $8 fix!! seems to be ok now ish....
Have had manflu but have been doing a few things today.
Posted 22 April 2009 - 07:28 PM
oh my!!! that looks beautiful boo. Top work!
#236
Posted 24 April 2009 - 03:58 PM
Thanks Jordie. This is the final build now. Just need to get the bodywork finished now
#237
Posted 27 April 2009 - 02:46 AM
Well with the engine nearly done and the bodywork no where near done i did a bit more on the body this afternoon. Quite pleased with how it came out. still have some tweaking to do but the cormer pieces look ok and after a bit dressing of the welds and a skim of filler it should look ok i reckon.
#238
Posted 30 April 2009 - 05:09 PM
couple of days off so hoping to crack on with fitting the rear valance and generally getting the back end finished. Then it will be onto the drivers side inner sill. then a few more spots around the car that need a patch or two and the welding will be done.
hmmmm makes it sound very easy.....
#239
Posted 05 May 2009 - 01:40 AM
Flipped the mini back up onto its side and finished welding the new wheel well in form underneath. also fitted the rear valance and cleaned uo the welds. Not the prettiest of welds but it is solid and most of it will be hidden by seam sealer and under coat.
Oh and i love my spot welder. makes things soooooo easy!!
Still have to finish the lower corner piece of the wheel arch as it was bad but i have rebuilt most of it and will weld in the final piece tomorrow probably.
#240
Posted 06 May 2009 - 06:26 PM
Just run out of welding wire again!! off to the shop in a bit to get some more. no pics as the bit i am doing is horrible. its threar seat base where it joins the bulhead. was rotten as hell inside and out. did the poutside a while ago, am now doing the inside. Once its done i will flick the car back on it side, tidy up and clean the rear end and get some seam selaer on all the welds.
Hopefully i can get the nack end of teh car finished today. Then I might even put the subframes abckl on and do the inner sill when it is on four wheels!!!
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
