1978 Mini Clubman K100 Twinky
miniboo
, Sep 05 2007 05:42 AM
263 replies to this topic
#196
Posted 05 September 2008 - 10:01 AM
#197
Posted 05 September 2008 - 11:00 AM
did you get all of them boo?
the only thing im confused about i the head's water outlet, has the drillings obviously 2 are bolt holes, wondering what the centre hole is probably going to see super daft now!
#198
Posted 05 September 2008 - 11:21 AM
Water temp sensor.
#199
Posted 05 September 2008 - 11:56 AM
aahhh good call batman!
#200
Posted 07 September 2008 - 03:30 PM
yep ordered teh whole lot. was easier than me bodging loads of stuff together to be honest. i had made a few *rubbish* prototypes with breathers and fuel pump block offs etc but nothing looked or worked right. Bling like that is the way forward
#201
Posted 07 September 2008 - 07:55 PM
hey miniboo, just ordered my k100 head to mess about with lunchtimes at work.. so still new to this stuff, and got a real soft spot for small bores.
when you blanked the bores to dry deck the block, what did you use to do this.. have read abut using cast iron plugs screwed in but also heard of them being abit soft when it comes to re-drilling the new head studs.. possibly use ms bolts tapped into the block and machined away.
or were yours a press fit,
cheers gaz
cheers gaz
#202
Posted 07 September 2008 - 08:34 PM
Hi boo...just starting to collect parts for my own k conversion and this has been fascinating reading, well done mate. do you know of anyone who has done the k conversion and is using carbs instead of throttle bodies. am not a fan of ecu's and modern electronics?
#203
Posted 07 September 2008 - 11:28 PM
@clubman katie: Yeah Gregg Temkin did the first ever conversion and he used carbs as he didnt want to spend out on teh ecu injection gubbins etc. I am probably going to start with carbs as i got some for 20 dollars and i have run out of money for an ECU at teh moment. I will be going with EFI eventually though.
Clubman Katie look here: http://www.lojomo.com/
@the soon to be:The block getting blocked at steel push fit inserts with nasty 620 loctite to make sure they defo stay in. Some were screwed in obviously where the original stud holes were. and the others were interference push fit.
#204
Posted 08 September 2008 - 11:42 PM
pics of yet another dry build. am waiting on a shorter belt so can sort teh tension out properly and then try and figure out the valve cut out positions.
Posted 09 September 2008 - 08:40 AM
Miniboo, do you have any more pics of the removable slam panel and how you remove it.
#206
Posted 09 September 2008 - 01:51 PM
yep will get some later if i rememeber
#207
Posted 19 October 2008 - 06:02 PM
never ever start poking with a screwdriver!!!! This is were i am at now after removing the battery box then the subframe and had a poke about and clean up. There is a lot of bondo/filler in the back end.
Posted 20 October 2008 - 04:58 PM
OOOOOPS
#209
Posted 21 October 2008 - 04:18 PM
i will get some more work done on friday hopefully. but i am thinking i might go and get it "walnut shell" blasted now. probs will be about $600-850 whioch aint bad really
#210
Posted 03 January 2009 - 01:54 AM
Hmm long time no update......
Well as its the new year i have decided to actually do something!! i have stripped out the interior and rear windows and started to look at the rust. some parts fo the car are mint and others have had lots of filler hiding some nasties. shouldnt need to much work but the boot is the worst.
Still might take it to the blasters. but i am not sure.
Also i have had my head uder cleaned/blasted and had all the valves lapped in etc etc.
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
