1978 Mini Clubman K100 Twinky
miniboo
, Sep 05 2007 05:42 AM
263 replies to this topic
#166
Posted 28 April 2008 - 01:23 PM
Lol, ah ok. Your just too quick for me then! Only get a pic if your remember next time your working on the Mini, tis nothing important.
#168
Posted 09 June 2008 - 05:34 AM
Bad news and Good news.
Bad news first: was out in the mini today and we broke down. AAA came and collected the car and dropped us back at the house. Had to push it up the drive while my 6 year old son steered!!
Good news: this means i will now step forwards and take the engine out which also gives me a kick up the bum to sort the "other" engine out!!
on first looks from stripping the ancillaries off(rad fan etc) it looks as though the crank bolt has come undone. which meant the nut holding the trigger wheel on had jammed up against the lower rad mount. hopefully i havent done any damage to the trigger wheel and bits that hold it on!! So all my own fault really!!
hopefully tomorrow after work i will be able to make an engine hoist bracket and get the engine out.
In the second close up pic you can see the trigger wheel at a jaunty angle!
Posted 10 June 2008 - 06:02 AM
just a couple of hours work after work!!
Made an engine lifting bracket and out it came. bit of tidying up to do now.
Posted 10 June 2008 - 08:00 AM
alot left to do to the twink then?
#171
Posted 10 June 2008 - 12:22 PM
hahaha yep
#172
Posted 10 June 2008 - 12:23 PM
come on....everyone has a list im sure u do aswell...whats left
#173
Posted 10 June 2008 - 12:27 PM
build gearbox.
machine pistons for cutouts and also sedge of cylinder wall.
buy and fit exhaust manifold.
buy and fit ECU
Buy and fit clutch assembly
Sort out the injection fuel setup.(incorporating twin tanks)
setup the whole engine once the piston cutouts have been done.
to be honest i have almost everything i need just need to buy some of the more major components and have sone work done on the pistons and block and then bolt it all together and throw it in!!!!!
buy and fit ECU
#174
Posted 10 June 2008 - 12:29 PM
its not toooooo much anyway, further than mine iv only got the k1100 head so far
#175
Posted 10 June 2008 - 12:31 PM
well i am closer than you LOL. i also have some k1100 throttle bodies and all teh bits coming as well. that means i have 2 lots of k100 throttle bodies spare.
#176
Posted 10 June 2008 - 09:08 PM
Come on Matt - not that much to sort lol. Things always take longer dont they.
by the way hate you for your slam panel !
and whats with the double water pump / fan pulley?
#177
Posted 11 June 2008 - 01:17 AM
Slam panel is a godsend and i thik is standard Aus design. double fan /pump pulley thing is from when it had a "fresh air pump" the emissions buster thing. it was removed long before i got the car.
#178
Posted 30 June 2008 - 10:21 PM
I havent had much time to work on the mini recently but i have been making a bit of progress. So after pulling the engine i decided to clean up and paint the engine bay area.
And i thought i would put in a gratuitous eye candy shot of a nice plane i saw at my flying club open evening.
Posted 01 July 2008 - 04:16 PM
looking good! as does the plane
#180
Posted 02 July 2008 - 12:49 PM
It looks orange in the pics but it is actually "cardinal red". i chose something cheap and easy to get hold of for when i get the outside resprayed.
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
