1978 Mini Clubman K100 Twinky
miniboo
, Sep 05 2007 05:42 AM
263 replies to this topic
#136
Posted 08 February 2008 - 07:25 PM
mine should look like that
#137
Posted 09 February 2008 - 02:34 AM
hmmm can anyone say "drydeck"
#138
Posted 16 February 2008 - 04:37 AM
Well i had a few days off work so i decide to fit the right hand petrol tank i got from Jammy. I didnt want to buy the fitting kit as it is quite expensive. so after a brainwave i thought i could use some ally strip from the local diy shop.
It turned out like this:
quite chuffed and i have a bit of ally left over to make rad bracket for the K100 conversion when it is fitted.
I also finally got the mini on the road by VERY roughly setting the toe in/out and driving down to the tyre shop to get them to sort it out. it was a pig to drive down but a joy to drive back. drove it straight for almost 3 days!! was great to be driving it again and having disc brakes on the front makes a massive difference.
I also ordered my kit from SC for the K conversion. and a touring steady from them aswell.
Also i started cleaning up one of the sets of throttle bodies that i am going to use. have started painting a few bits and bobs aswell. not sure on the colour of the engine yet but i am going to have black detailing on all the small parts. alt bracket,parts on the throttle bodies, head cover, etc
#139
Posted 16 February 2008 - 08:21 AM
Hey! That RH tank looks pretty darn sweet, nice DIY strap too.
Got your PM earlier, there is a bit that fits over the splines, but I believe that was already on the steering rack, and my attempts to remove it when I was taking the Mountney boss off were futile, so I just assumed it was part of the steering column. I'll have another bash at it later...
#140
Posted 16 February 2008 - 08:38 AM
nice work
#141
Posted 16 February 2008 - 02:54 PM
cool thanks Jammy
#143
Posted 06 March 2008 - 11:30 PM
Ah cool, where did you get your oil feed from in the end?
#144
Posted 07 March 2008 - 07:37 AM
got it from minispares as i get it vat free and with discount. problem is i have an oil pressure switch and the feed and also an oil pressure gauge to try and plumb in now!!!
Any ideas?
Any ideas?
#145
Posted 07 March 2008 - 10:04 PM
You need an 1/8 NPT T piece and a couple of male-male adaptors to fit this T piece onto the one you get with turbo oil feed, you'll then have 3 outlets.
I ditched my oil pressure switch as my eyes are generally glancing over at the presure gauge instead, as you can tell when the oil is getting hot etc...
#146
Posted 07 March 2008 - 10:59 PM
true but i like to see a bright light if it all goes wrong. although i guess i could ditch the light aswell.
#148
Posted 14 March 2008 - 10:07 AM
Nice shiny trumpets!!
I sent off that steering wheel hub thing on.... Wednesday?! Apparently you should get it Mon/Tues.
#149
Posted 15 March 2008 - 04:34 PM
went to the shop again to have a chat about the engine and probable ways forward. the block has been bored to just under +80 so there is room for the final hone. just need to get the block skimmed and then do a dry build for the piston cuts and also work out the CR.
few pics f the block with all the holes now blocked up.
#150
Posted 15 March 2008 - 05:01 PM
are the blockings still sitting over the deck at the mo? why it needs decking
still needs extra drillings done too? your doing dry deck conversion arent you?
