I thought I read somewhere that it is possible to fit a distributor to an MPi engine, allowing it to be used as a normal carb and dizzy engine.
Can anybody confirm this is correct?
Mpi Distributor...
rallymini
, Sep 04 2007 07:30 PM
6 replies to this topic
Posted 04 September 2007 - 07:30 PM
Posted 04 September 2007 - 07:47 PM
possibly. but you would need to machine the block to accept the dizzy, change the camshaft so it has the distributor drive gear on it and possibly change a few other things.
Posted 04 September 2007 - 09:22 PM
I was afraid you were going to say that. I thought I read the dizzy hole was simply blanked off and a standard cam used, I guess not.
Posted 04 September 2007 - 10:03 PM
Yep, MPi block, no dizzy, not even a slim chance of trying to fit one.
You are thinking of the SPI, The SPi block just a plain ordinary A + block
Why do you ask this, out of interest?
Posted 05 September 2007 - 01:29 AM
you could run an mpi block with megajolt though.......but not a normail mini dizzy
Posted 05 September 2007 - 05:56 PM
yeah run the mpi with no dizzy, using a megajolt ecu, but use a carburettor for fuelling. at least you wont suffer from wet dizzy problems.
Posted 05 September 2007 - 06:00 PM
Will never ever pass the MPi emissions, and there would be no way of hiding the fact its an MPi block either
