Floor Mounted Pedal Box
14 replies to this topic
#1 mini-sprite
mini-sprite
  • 26 posts
Posted 03 September 2007 - 09:58 PM
Has anyone fitted a floor mounted pedal box to there mini to keep the master cylinders inside the car? Maybe as a race setup. Or has anyone got a photo of one fitted?
Paul
#2 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 03 September 2007 - 10:16 PM
not so likly to happen in a mini, the floor monted box's are usualy put in cars with flat floors where the windscreen height is low and the driver also sits lower down and further back
you can get KAD brake bias box, basicly 2 cylinder one to front 1/2 other for the rear, i had a twisting knob on the dash and as you turn it pulls the bar for the bias each way adjusting bias front to back
and heres a piccy of mine
#3 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 03 September 2007 - 10:24 PM
so how does that plumb in then? does it just go direct to the discs at the front and then teh drums at the back?
do you need any of the fam valves etc?
#4 mini93
mini93
  • 8,615 posts
Posted 03 September 2007 - 10:35 PM
on mine iv got braded brake lines from the box, goes to a T piece split then attached to the subby, its then got different braded lines to the calliper (which are brake specific goodrich types, just the same as when people usualy get braded brake lines)
to the rear split, in the system i have a verticle hydrailic hand brake (for turns :lol: )
basicly it the same line to the rear put just goes through the HB system, when it isnt pulled fluid just flows as normal and when pulled it doesnt develop pressure forward of the HB and only locks the rears
the braded line is also split on the rear subframe as usual sort of fassion then again to normal goodrich hoses which have the right thread on the end to go to the drum cylinder
#5 mini-sprite
mini-sprite
  • 26 posts
Posted 04 September 2007 - 08:56 PM
I was thinking of this one.
Space is at a bit of a premium as its taken up by the throttle bodies and air filter
This was taken a while ago. Ive got a pedal mounted master cylinder for the brakes with a remote reservoir at the moment. i want to run a hydraulic clutch as well.
#6 who_loves_the_mini?
who_loves_the_mini?
  • 1,314 posts
Posted 04 September 2007 - 09:09 PM
I know its not floor mounted but how about something like this? doesnt look like it takes up much space, but then i dont know how much space you have available.
http://www.gprdirect...rect....&2A
for floor mounted these look rather nice?
http://www.gprdirect.......p;2D642
http://www.gprdirect.......TLT72
i especially like the last one :wacko: ;) :dontgetit:
Edited by who_loves_the_mini?, 04 September 2007 - 09:11 PM.
#7 mini93
mini93
  • 8,615 posts
Posted 04 September 2007 - 09:11 PM
aah...riiight yeah cant see KAD set up fitting, floor mounted ones... depends how far back you want to sit to where which u could place the pedel box flat on the floor, you will then get seating and steering wheel issues tho
Edited by mini93, 04 September 2007 - 09:11 PM.
#8 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 04 September 2007 - 09:12 PM
Iv got exactly the same problem mate. My throttle boddies are going to be in the way. Iv been looking at an internal pedal box with remote maters. 16 Valve mini shop does one I think.
#9 mini93
mini93
  • 8,615 posts
Posted 04 September 2007 - 09:13 PM
oh also, what clutch you running? hydraulic or cable? different things to consider remember
remember it might be a little tricky to route the wiering for the accel as you might have to get custom as standard jobbie might not adapt your pedel box or engine also unlikly to be long enough
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 September 2007 - 09:44 PM
Have at look at a tilton set. Seen them used on a vtec mini in mini world issue summer 2007 (these things have numbers?)
#11 mad4mins
mad4mins
  • 1,396 posts
  • Local Club: WAMO!
Posted 04 September 2007 - 09:51 PM
ian curley had a set of floor mounted pedals in his miglia
it can be done but the resevoirs (sp) have to be remotely located (hence you can see the hoses run up the bulkhead).. the cylinders are mounted directly to the box. which is a problem especially in a mini as they stick out a fair bit so they need to be moved further to the rear of the car
*cough* final year uni project *cough*
designed for out 206 race car..
Edited by mad4mins, 04 September 2007 - 09:54 PM.
#12 mad4mins
mad4mins
  • 1,396 posts
  • Local Club: WAMO!
Posted 04 September 2007 - 09:58 PM
i thought all mini's were hydraulic????? therefore making the installation a little easier
brakes - hydraulic master cylinder replaced with cylinder mounted behind pedal
clutch - hydraulic cylinder also replaced with cylinder mounted behind pedal
acclerator.. - the tricky part in my view.. see curleys drawing above, the outer cable can be clamped to the body, which is the easy part. but in lehmans terms. the pulling motion has to be translated into a pushing motion (pedal).,.
so i think a pivot method like curleys is an easy way to over come this...
the remote resevoirs could then be bolted where-ever on the car... will try and dig out a pic of where Bill Sollis mounted his
Edited by mad4mins, 04 September 2007 - 10:04 PM.
#13 mini93
mini93
  • 8,615 posts
Posted 04 September 2007 - 10:18 PM
yeah minis were hydraulic run, but that engine isnt mini engine, and a some metro's ran cable clutch i believe
as for accel cable, if the pivot point is moved up, so theres a bottom continuation of the arm the cable can run fromthe bottom, we had this in project vehicle in college, same principle except these were verticle mounted. just have to think if it protrudes to where the foot should be, can be over come with pedel design tho
unless theres a way of running electric throttle, setting up a position sensor on the accel pedel, input to ECU infiguring where is it, then on throttle bodys a stepper motor would open the butterfly a certain amount determined by ECU...long way round but some VERY good engineering if done and shoud work...never worry about snapped acel cable aswell lol
Edited by mini93, 04 September 2007 - 10:20 PM.
#14 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 04 September 2007 - 11:05 PM
You can run the Vauxhall gearboxs with hydralic clutches. Again all the parts can be obtained from Alssped or 16valve mini shop.
#15 mini-sprite
mini-sprite
  • 26 posts
Posted 05 September 2007 - 10:01 PM
Ive got an F18 hydraulic wide ratio gearbox. Ive also DTH throttle bodies so they dont stick out as far as yours do with an inlet manifold. I'm going to fit some stumpy stacks on it and fit the thinest ITG air filter (JC50-25) ive got 2 new master cylinders and they will fit just nice in the normal place. I need to get a standard mini pedal box now and will be selling my Allspeed converted pedal box in a few weeks.
Paul
