Rusty The Minus (aka Mr Hoskins)
697 replies to this topic
#91 GraemeC
GraemeC
  • 7,438 posts
Posted 25 September 2007 - 08:29 AM
I would still be suspecting the starter motor - I went through three re-con units on my auto-test car before I got a reliable one and the symptons were identical to yours, even with directly connected jump leads. What does the starter do if you connect it up when out of the engine?
I also found the engine very difficult to turn over by hand - I think the starter was sticking somehow and the pinion was staying engaged.
Also you said you connected the -ve jumper cable to the starter bolt. Is there a good clean connection between the bolt and the starter body, or the starter body and the flywheel housing?
#92 Jammy
Jammy
  • 25,397 posts
Posted 25 September 2007 - 08:35 AM
Hmmmmm, I may try a brand new starter from Minispares I gues....
When I connect the starter up out of the engine it spins up fine. The bendix moves up and down the shaft easily. I have two recon jobbies and both are the same.
Yea, all the connections have been cleaned rigorously.
As I say I've tried starting the engine with the clutch cover off, so I know the starter is engaging and disengaging properly, everything seems to be working as it should, its just not turning over quick enough.
#93 GraemeC
GraemeC
  • 7,438 posts
Posted 25 September 2007 - 08:47 AM
When you jumpered off the Halfords battery was the original still connected? Disconnect it first to eliminate any drain it might have on the new battery. As an experiment I would even be tempted to remove the earth strap from the engine to isolate it from the rest of the car - a dodgy earth connection elsewhere could be enough to take power from the starter, especially of the starter is struggling.
I would expect the engine to turn slower at TDC & 180 as the pistons and rings change direction. Take the plugs out completely - if the engine turns over then then I would not suspect it to be the problem at this stage. Especially if you can turn it over by hand woth a socket & ratchet on the crank pulley bolt (or flywheel bolt as you have the cover off).
My money is certainly on either a lazy starter or a still dodgy connection somewhere.
#94 Jammy
Jammy
  • 25,397 posts
Posted 25 September 2007 - 08:53 AM
Hmmm, I can turn the engine over by grabbing the flywheel with the clutch cover off. And with the spark plugs out I the engine does turn over a lot quicker as could be expected.
I'll get a brand new starter and go from there then!
#95 Jammy
Jammy
  • 25,397 posts
Posted 26 September 2007 - 12:58 PM
Got my brand new starter motor at lunch today, from Minispares (linky). Fitted it, and with the choke out the engine started quicker than I've ever had a mini engine start!!
So GraemeC, if/when we meet, I owe you a big wet kiss! :gimme:
#96 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 26 September 2007 - 01:02 PM
I am sure he will be pleased with that!
#97 GraemeC
GraemeC
  • 7,438 posts
Posted 26 September 2007 - 01:06 PM
Bu66er. I'm off - and not down south!
Simon - do I get comission on that starter I just sold for you??!!
#98 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
Posted 26 September 2007 - 01:23 PM
Nope! :gimme:
A kiss from Jammy not enough?
Edited by [email protected], 26 September 2007 - 01:29 PM.
#99 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 27 September 2007 - 03:28 AM
i think that would be - ve lol.
#100 *Raz*
*Raz*
    PC Hands
  • 4,039 posts
  • Local Club: Brighton
Posted 27 September 2007 - 12:18 PM
So GraemeC, if/when we meet, I owe you a big wet kiss! :)
can i watch :) :thumbsup:
#101 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 September 2007 - 12:29 PM
What are the size/width of those wheels you've got? Are they 6 x 10? If they are can you let me know how much they're sticking out of the body please?
Looks really good, probably won't need painting :thumbsup:
#102 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 27 September 2007 - 12:31 PM
Just so you know paul.... not all 6x10's will have the same offset so unless you're buying those exact wheels, a measurement wont be much use.
#103 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 September 2007 - 12:39 PM
Yeah good point, though I was thinking Wellers would look pretty neat
#104 GraemeC
GraemeC
  • 7,438 posts
Posted 27 September 2007 - 03:23 PM
Raz - if we let you watch how are you going to return the favour?
paulrockliffe - I have a vague memory Jammy was selling those wheels so don't want to p1ss on his bonfire - but if I'm wrong, and you want some, let me know :thumbsup:
#105 Jammy
Jammy
  • 25,397 posts
Posted 27 September 2007 - 05:25 PM
The fronts stick out about 4.5-5", but with an inch spacer. The backs are about 3.5-4". I'm selling some 10x5 Weller motorsport wheels. Like the ones the Minus has, but round holes, instead of straight spokes.
