Rusty The Minus (aka Mr Hoskins)
#181
Posted 24 October 2007 - 11:25 AM
#182
Posted 24 October 2007 - 11:34 AM
Have been checking out the ratios of the gearset I have. Looks like its a ST Abingdon set, at least 2nd and 3rd match those ratios. I have a standard 31 tooth 1st gear, so need to dry assemble the box and see if that gear even works! If not a 29 tooth 1st gear will be ordered from 'Spares. All in all this £420 gearset (new from 'Spares) will have cost me £110 or £170!
I believe if you have standard first gear then you may have a clubman gearkit. Its what i'm using, it uses the standard first and reverse. The 2nd, 3rd (and obviously 4th) are the same as the ST ratios. 1st is slightly different however, it has a 2.55 ratio as opposed to a 2.58 thats on the ST gearset.
Nice build jammy, good find on the gearset too, i've been lookin on ebay for ages, cant believe i missed them, u live up to ur name dont u - cept the 'Dr' bit
#183
Posted 24 October 2007 - 12:34 PM
I think it was one of the best bargains I've had, as long as it all works!
#184
Posted 28 October 2007 - 09:27 PM
Picked up the gearbox which was slightly (understatment) grimy and dirty:
So part of Saturday afternoon (after I'd got home from work) was spent cleaning it up. Initially I set about with a few wire brushes and hot water with washing up liquid. This was somewhat effective at getting the worst of the grime off, but after a good 30 minutes I started to think there was a better solution! So off I go into the garage to fetch the WD40, on my way out I spy a can of carb cleaner and decide to try that too. Well the WD40 wasn't bad, but the carb cleaner was something else! In no time at all I had all the grime just dripping off the gearbox, but had also emptied the can (it empties VERY quickly), so had to get a couple more cans from Halfords. Anyway, below is what it looks like now.
As for the general condition of the gearset, well it turns over very freely and there doesn't seem to be much play, however those gears won't be staying in it for long, I bought this box solely for the diff. Counted the pinion teeth and I make 17, so its either a 3.6 or 3.7. I'm hoping it'll be a 3.6 as I'll then just be able to swap the pinion for an 18 tooth one and get a 3.4 FD which would be better for those longer journeys. I'm hoping to strip the box tomorrow night and dry build it with the SC gearset so I know which replacement parts I need to order from Minispares this week.
Oh, and one call tomorrow morning and hopefully 'IT' should be arriving this week!
#185
Posted 28 October 2007 - 10:00 PM
#186
Posted 29 October 2007 - 04:31 AM
great project by the way.
#187
Posted 29 October 2007 - 09:50 AM
#188
Posted 29 October 2007 - 10:17 AM
#189
Posted 29 October 2007 - 10:30 AM
Also, should have said earlier, if you plan to use carb cleaner for any sort of cleaning, wear some safety glasses! I got the carb cleaner in my eyes a couple of times and it stings!
#190
Posted 29 October 2007 - 11:16 AM
#191
Posted 29 October 2007 - 12:52 PM
so dont clean your box in loose under pants
#192
Posted 29 October 2007 - 06:07 PM
-As for the door skins, they would need to be bonded with glass filings in the resin. This is basily chop strand mat, chopped up really fine either with a pair of scissors or in a blender. whing you add this to the resin it makes a thick paste. Plus you have to clamp the skin to the door frame and let it set for 24/ 48 hours.
Edited by Alburglar, 29 October 2007 - 06:08 PM.
#193
Posted 07 November 2007 - 01:13 PM
#194
Posted 07 November 2007 - 01:18 PM
#195
Posted 07 November 2007 - 01:20 PM
