Air horns
Posted 21 January 2005 - 09:18 AM
Posted 21 January 2005 - 10:22 AM
And here's a pik of how to wire them up...
You can always use the fuse for the positive feed. That way you wont need to run a cable to the battery and all wiring is kept neatly under the bonnet. Also if your buying the Mini Shop London ones you'll need a 25A fuse as it keeps blowing the 20a one .
Hope this helps,
Jam2005 :grin:
ps. Sorry about the big piks .
Posted 21 January 2005 - 01:06 PM
Posted 21 January 2005 - 02:57 PM
Posted 21 January 2005 - 04:39 PM
Jam2005 :grin:
Posted 22 January 2005 - 11:29 AM
Posted 22 January 2005 - 12:22 PM
Posted 22 January 2005 - 12:29 PM
do they only play one or can they play differnet ones?
Posted 26 January 2005 - 09:01 PM
VERY LOUD
Posted 26 January 2005 - 09:58 PM
Use the existing terminals as you have done but put them onto the coil terminals of a relay instead and then run some more, slightly heavier gauge wire from the solenoid, through a line fuse then on to the load terminals of the relay and then to the compressor, which also needs an earth.
Posted 26 January 2005 - 10:15 PM
Posted 26 January 2005 - 10:27 PM
MAN those things are loud!!! I think they seem even louder because of how out-of-tune they sound. VERY irritating noise!
I also have twin airhorns fitted to the car but not wired up to supplement these
Posted 26 January 2005 - 10:32 PM
I don't want any fires or melting of wires so consider it done my friendIt is a good idea to use a relay in an air horn circuit, as it is in a twin horn setup. The twin horns or compressor draw a lot more current than a single horn does and the wiring isn't really up to it, you can get away with it because you generally don't use the horn continuously but it can lead to some loom melting or even a fire.
