So on friday i worked from 9am till 11pm on the car getting it ready for respraying!
Didn't take a massive amount of pics because i was dead busy.
I started by applying filler to any exterior holes which i had previously filled with fibreglass from behind, such as the ones under the rear screen and under the off side rear lamp. I also applied some filler to the roof over the fibreglass.
I find filler pretty hard to work with so as you can see i just slapped a slab of it on and smoothed over it as best as i could. I reckon its better putting too much on and having more sanding work than too little and have to start again/apply another layer.
Looked pretty bad but its ok lol
I was wondering if i should remove the headlamp bowls or not to sand round them and rust treat etc because they had been riveted in... In the end i decided to remove them because i'd seen some bubbling of the paint around the headlamp a few months ago. So i had to grind the top of the rivets flat and used my nanas ancient electric drill to drill them out - which was a right PITA since the drill only works when held at a 45 degree angle due to a loose connection!
So finally got those out and started sanding round them. I was expecting to find some serious surface rust but there was nothing there at all really
So i rust treated around the sanded areas:
Mini looked like it had black eyes
I then sanded down any filler work i'd done, the upol easy sand stuff i used sanded like a dream!! Really easy to sculpt and sand (does what it says on the tin i guess) So once that was done i busted out the hammerite and paint over all the parts which wouldn't be getting sprayed. So i painted the parcel shelf and and the rear valance and in the bonnet gutter.
Next i decided to remove the nearside rear lamp to rub around that. I hadn't done that before because i couldn't be bothered moving the tank. But i decided i better do it incase there was any rust that needed sorting. So i moved the tank into the centre of the boot and the lamp and started sanding away and generally carrying on with stuff. I could smell petrol but thought it was just because i'd removed the the filler cap breifly but when i could still smell it really strongly 5 minutes later i got abit worried.
Looked in the boot and noticed there was a puddle of petrol in the spare wheel recess!! So lifted up the tank to see where it was coming from and it started pouring out and filling the spare wheel recess rapidly!!
This is when panic struck and i reaised it could go bad so i quickly grabbed a spanner and remove the battery and turned off the electricity supply to the garage. Everytime i lifted the tank to see where it was coming out of i just seemed to get worse. By this point i was soaked in petrol right up my arms and hands i was really starting to sweat!
It looked like it was leaking from the hose. So i removed the tank from the boot and poured the fuel out into various containers. Once i'd mopped up the fuel from inside the boot floor i had a look at the pipe and realised that by moving the tank to the centre of the boot i had pulled on the pipe which had caused it to split right next to the hose clip and that by lifting the tank it stretched the hole open and made it worse!
Luckily because it was right near the end of the hose i was able to just cut 10mm off the hose and re-use it. Panic over and the tank went back in fine later on - Phew!!
By this point time was getting on and i had loads to do. So i drafted in a mate to help. He spent some time sanding around the screw holes for the grill and arches and sanding inside the bonnet gutters and grinding down some dodgy welds that had been made in there. While he was at that i mixed up some more fibreglass to fill the un-needed with.
I filled the arch holes and also grill holes:
No pics of the grill holes but they turned out alrite.
I can't remember what i else it did but i did loads of little jobs which took about 4 hours and before i knew it i was tired, starving hungrey, thirsty and generally ready to stop work. But the car had to be ready and i still had loads to do. So i carried on and finaly got everything finished.
Worse part was putting the new boot on. I put the hinges back on the body nice and tight, went to put the bootlid on, got one hinge bolted down, went to do the other - DOH! Who said hinges were sided! So they had to come off again and redone.
Anyway then i quickly went over the car giving any vunerable repairs a spray of paint. The grill and arch fibreglassing and the roof repair etc:
Filler work looks abit dodgy on the roof but the bodyshop guy will sort it.
We then put the windows back in and masked up the rear window for driving down there the next day.
After everything the car looked like this:
We did manage to get the car to the shop by friday and the guy seems like a nice guy, i'm confident he'll do a good job
