All i've been doing really is cutting out the rusty shock mounts. Its been a learning experience really because I didn't know that area of the car was as complexed as it is. When I first removed the shock mount itself and saw the hole behind it I thought I could just cut the rusty square out of the inner wing and get a plate welded in and it'd be done. But once I started cutting I realised the area was made up the bulkhead box section with threaded blocks welded into the end of it, a stiffening plate and then the inner wing itself, all welded together.
But i've been cutting and grinding for the last few weekends now and i've almost got it to a stage where all the rot is cut out and its ready for welding. The drivers side is worse than the passenger because the top of the box section had pretty bad rot, which had spread to a small area of the triangle stiffener on the inner wing. So thats all be cut out and the end of the box section has been cleaned up and filed to get it ready for welding onto:
Heres how i'm planning on repairing the top of the box section, should be nice and strong with the tabs welded into the sides of the box section:
Passenger side i've not got as far, but then again it does need as much work as the box section is solid and doesn't need much prepping (crap photos)
The passenger side needs the left side of the box section finishing off, it needs grinding more to remove the last bit of metal which is spot welded to it, then I should be left with a solid end to the box section to weld to.
I've also bought a 'poly tunnel' green house to cover the car with. The cover I've got is abit worse for wear now and has some little tears in it hear and there from being pulled on and off so often, so in the heavy rain and wind we had, water was getting trapped up it against the paint. So I thought i'd best take it off and get it breath. So now i've got this plastic green house which covers it well and has venting windows on the side so it doesn't get humid in there. Its got just about enough room to work in aswell about 0.5m around the car, so hopefully aslong as its not too windy i'll be able to work out in the rain now its getting towards winter.
