Well last couple of days have been quite productive because the rains held off. Thurday I was out so didn't do anything but wednesday and today i've had good days at it.
I've hand painted round the edge of the 2 wheels where there was the yellow of the primer showing through. Thats come out well i've just got to work out how to remove the excess from the dish now without damaging the new paint or scratching the dish....
Today I wired brushed off the suspension arms and ties bars and gave them a coat of hammerite which turned out well:
Then got the driveshafts in. I made a newbie mistake and strapped the inner pot joint boot on, then realised the pot joint doesn't fit through the subframe!
So they had to come back off and I just re secured them with cable ties because there was no way theres enough room to fiddle with the metal straps once the joints in place. Then the refurbed hubs could go on:
Followed by the new vented discs:
So i'm pretty happy with all that. The engine can now be refilled with oil, then the exhaust can go back on and it can be started up to harden the exhaust sealing paste.
You'll notice the underside is looking pretty bare now aswell. I've wire brushed all the old underseal and most of the paint off. There a couple of holes i've found unfortunately. The scuttle closing panels aren't looking too good, but its down to a previous owner/garage fitting them quite poorly. They're pretty shielded from direct water spray by the heater/vent intakes but I think i'll just give them a proper clean up and paint all over them.
I've got por15 and metal ready on order for the underside, so thats the next main job. Por15 only sticks to bare metal though, so its going to be a big job getting all the old hardened paint off, because the wire brush attachments are falling apart now. Think i'll have to order some proper paint removing attachments.
Heres how its looking though:
So there still a fair bit of paint to get off yet before its ready to be redone, but if the weather stays alrite, its only another days work to do that. Then again i've then got the rear arches, sills. floors and boot floor to do then
