Just read your project thread. Very helpful. You seemed like a seasoned professional when it came to putting the engine back together, hope it runs first time for you! Have you reconstructed/refurbed an engine before? Don't think its fair to call your procrastinating mate a friend, other people don't seem to appreciate what it means to get a Mini perfect.
Best of luck from here on in, looking forward to seeing you refit that Mk1 grill and put those finishing touches on.
Thanks for the comments - The engines never ran yet so i'm still holding my breath!
But yeah that was the first time i'd ever seen the inside of an engine before. It was a learning experience for me, I just used the building a 1380 A series engines DVD - Found that really helpful and it was full of little tips that the haynes doesn't give you.
MiniAlex - The dials I added were obviously just off a later mini - They bolted straight in and the rev counter wiring is already included in the wiring loom of the car - But just not used.
If you take your 2 clocks out and have a fish around you should find a loose black/white wire somewhere. Thats your connection from the coil to the rev counter and should be the one you need to run it.
Only update I have is that steve at SD minis has informed me that the car is now black again! Just got the bonnet and bootlid to spray, then he can crack on with the engine and things. So yeah i'm hoping to have that back fairly soon so i can start the rebuild. As of today i'm finished for summer at uni now too so i've got all my time spare. Hoping to get the car back on the road ASAP - Its been far too long since i've driven it.
Although saying that i will have a fair bit of work to do and will need a few good hours spent on getting it MOT prepped too. I know the brakes need bleeding at least and the balljoints could probably do with replacing. I don't want to rush it, but I will be working hard on it aslong as the weathers not too bad.
