A Question On Waxoyl
Posted 19 August 2007 - 12:33 PM
I plan to purchase a 2000 Cooper sport, and if it hasnt already been waxoyled, I want to have it done. Halfords sell the clrear stuff, and the black stuff, but I have the large clear waxoyl with the pump trigger etc.
To waxoil the underside and arches, is the clear stuff OK to use? Its just that the black Waxoyl undearseal stuff looks horrible!
Posted 19 August 2007 - 01:16 PM
Posted 19 August 2007 - 01:55 PM
The clear is much better as I always think to see the body colour under arches etc is best. Also, I reckon i will do about 4000 miles a year as it will be a weekend summer driver only, and to the odd mini show.
My Mk1 Cooper has the clear waxoil everywhere underneath, not the black underseal one.
But is the Waxoyl clear as durable as the Waxoyl underseal black stuff?
Posted 19 August 2007 - 02:11 PM
waxoyl once a year, and you should be rust free for ages. i use the aerosol version or the extension probe for the hard to reach bits like under the scuttle panel, inside sills etc. it does wash off after a while, so i do it once a year before winter. same time i check for any new rust etc.
there is a black coloured waxoyl which is the same as the clear stuff, not to be confused with the black waxoyl underseal!
Posted 19 August 2007 - 02:47 PM
Posted 19 August 2007 - 02:48 PM
I think having a black underside looks neater myself, but each to there own.
Posted 19 August 2007 - 03:47 PM
I already have the Waxoyl clear stuff in the big pressure can, trigger hose etc. I thinki then I will use it for all of the areas when I get my new Cooper Sport. For My MK1 cooper, thats already waxoyled in clear in 2005, but has done only 1500 miles since it was applied, and is always garaged. But I will be waxoyling it again this year.
As for my future use of Waxoyl, with the clear I can see the bodywork paint once it is applied, and so notjing will be "hidden" as it would be if I used the black stuff.
The clear stuff it is then!!
Posted 19 August 2007 - 08:06 PM
The black underbody sealant stuff that contains Waxoyl is actually very good and so long as you inspect it once a year, brush off any that has gone loose and then reapply a fresh coat, then it will do the job very well.
I think there's a fine line between whether you want you're Mini to look original/concourse without actually using it much, or whether you want to use you're Mini often and want it to last.
Anyway I've had that black underbody sealant stuff applied to my wheel arches for many years and their still in pretty good shape both inside and out.
Posted 19 August 2007 - 08:34 PM
have to say the waxoyl underseal is miles better than the cheap stuff, just make sure panels are clean before slapping it on. if i did it, id spray the panel white, then put the black under seal on. that way any stonechips show up easier and of the underseal starts 'lifting off' it adds a little extra protection.
i dont use it because its an absolute bugger to get off when your welding!
Posted 20 August 2007 - 01:25 AM
After all those posts about using clear or blackm shall we have a votes as to what I should use???!! LOL!! I prefer the clear waxoyl, so, will I be OK using that? I it doesnt cause any problems its what I will use.
John
Posted 20 August 2007 - 06:28 AM
Posted 20 August 2007 - 07:29 AM
Posted 20 August 2007 - 11:57 AM
But like I said, even clear Waxoyl is going to be visible and will look like dried porridge once it's set so it's probably best to only spray that inside box sections and hidden areas.
Posted 20 August 2007 - 04:05 PM
Posted 22 August 2007 - 12:16 AM
Anyway I just heated the can up in a jug of nearly boiling water for a few minutes and it all squirted out a treat with no blockage.
I've got a large tin and full application kit all waiting for when I fully rust proof my Mini, but I've heard that you should add a little white spirit as well as heat it up to get it flowing nicely. Then it's more likely to creep into every single crevice.
Edited by taffy1967, 22 August 2007 - 12:16 AM.
