ok now! step by step guide to reshaping your boot floor to accept a fuel cell!
Step 1: cut out spare tire holer and battery box. depending on the size of the tank, you may need to extend the rear bar of the subframe.
Step 2: cut sheet metal piece slightly bigger then the hole you made. bend to get a real basic curve that is somewhat similar to the way the edges of the boot sort of swoop up and back down to clear the subframe. you can use your knee for this and a deadblow hammer, it really isn't that hard. push sheetmetal back so it jams between the edge of the floor and the back seat, and tack it in. put weight on the panel as it you tack it to the general shape. at this point it is still an overlap joint so it should overlap the original floor about an inch or so on almost all sides. Picture was takedn a bit later so that is why some of the seams are welded.
Step 3: after it is al tacked, go around the edge of the panel you made and cut the trunk floor right where it intersects the new panel. go in about 2 inch sections and re-tack the butt joint so it remains the same shape. do this all the way around until it is now just all butt joints. seam weld.
Step 4: for the joint where the panel meets the rear seat, there is this strange sort of downwardnotch that runs most of the length of the panel. cut the panel as close as you can and weld it to the back seat. grind it and it should look like this:
in that picture you can see where the new panel just goes straight across, the seat back is flat the whole height so it is just easier. also, i welded the frontmost seam to the backseat from underneat, as inside with the angle it would be hard to weld and almost impossible to grind. so i went from underneath.
Step 5: Prepare boxes that are the right dimensions for the battery and the fuel cell. make them about 2 inches taller then they should be, for reasons i will get to later.
TO BE CONTINUED
also, got my steering wheel and guages. the wheel was one of the only all black wheels i could find for a decent price, and while the shape of the wheel is very nice the plastic feel is dissapointing. I think will just trim it with black leather at some point. The guages are all autometer, phantom series.
everything is in a temporary setup at the moment, that is just how they are mounted for startup.
