73 fast road mini
#241
Posted 02 December 2010 - 07:13 AM
-weight
-cost
You can buy complete D15B swaps for $600 while imported B16s run $2000+. A D15B full swap only weighs slightly over 300 pounds, which is around 100 pounds less than any comparable b-series, and about 30 pounds less than a stock 1275.
I live in Moorpark, by the way. One of you should come give me a ride, I've never driven much less ridden in a mini.
#242
Posted 03 December 2010 - 12:56 AM
I was only asking because i also think the d16/d15 is a much better choice for a ton of reasons.
when a few things are fixed on my car, my brakes suck so bad ordering some kad brakes. and i have a remote shift trans and i cant drive the car on the freeway it revs sooo high so i need to buy a rod shift trans.oh and i need to rebuild the carb this weekened lol
the life of a mini hahaha
but when thats all done im going to take a road trip up to paso to go drink some wine so i will hit you up, by the way car is looking good and i have seen so many projects never get finished i hope this dose not happen here.
#243
Posted 17 December 2010 - 12:29 AM
#244
Posted 17 December 2010 - 02:52 AM
I'm in the middle of doing a wire tuck, I'll post some pictures when I'm done.
#245
Posted 28 December 2010 - 12:42 AM
#246
Posted 28 December 2010 - 01:28 AM
After reading that and seeing how good yours looks, im tempted to do a d series now.A D15B full swap only weighs slightly over 300 pounds, which is around 100 pounds less than any comparable b-series, and about 30 pounds less than a stock 1275
Not sure i should say it but, keep up the good work Chris
Edited by charie t, 28 December 2010 - 01:29 AM.
#247
Posted 28 December 2010 - 04:54 PM
Probably been asked before, but aren't you doing it the wrong way round?
Although I suppose this way you know exactly what will go where and aren't causing any damage to the what could be painted shell.
#248
Posted 05 January 2011 - 06:23 PM
Been cleaning the garage as well, but no pictures of that.
analogue_radio, usually this would be considered a "dry build" but I plan on running it in primer for a period of time until I spend some time sorting out the chassis. I'm not too worried about it either since it's not very likely for any rust to form here.
Back to the garage!
#249
Posted 05 January 2011 - 06:42 PM
Back to the garage!
Chris, can you please detail your harness build!? I am doing mine shortly, and would love to have something to follow. So far I have the engine harness and the ecu harness (in transit to me) for the interior. Not sure if I need an underdash harness or not, or the ecu harness would suffice to plug into the main relay.
#250
Posted 05 January 2011 - 07:55 PM
Here's the gist of what I did:
-D16Z6 harness
-Re-routed all the wires so that it fits through the holes I made in the firewall
-Removed unnecessary circuits (basically everything that the ECU doesn't see, ex. backup lights, oil pressure idiot light, a few other little things)
Other than that it's pretty much untouched.
-Traced every circuit from ECU pinout to plug, labeled each wire with the correct ECU pinout number, and gave them a snip.
-Shortened the entire thing to around a foot and a half long
-Went from pinout to connector for each individual circuit, as noted in the electrical manual
-Wired up the main relay, here's a little diagram of how mine is. Some of them have socket 4 blanked instead of socket 6, but if you can reference the electrical manual it doesn't really make a difference.
Socket numbering:
I wired mine up like this, the letter/numbers represent the ECU connector pinout number:
A25/B1 are spliced, as well as A23/A24.
After everything is connected, the only wires that I had to connect to the rest of the car were:
-Start signal
-Fuel pump +12 (from main relay, I'm grounding this though as I'm using a separate relay for the fuel pump)
-Switched power +12 (connect to fused key-hot battery source)
-Constant power +12 (connect to fused always hot battery source)
-Charge system warning light
-CEL light
-Service check connector
With all this being said, I tested each circuit with a multimeter, but the car hasn't run yet so I can't be certain that everything works. I wouldn't follow this guide until I get this thing running, and diagnose any issues that may arise.
It's really not that hard when you have the electrical troubleshooting manual. I would have been lost without it.
#251
Posted 05 January 2011 - 08:08 PM
#252
Posted 08 January 2011 - 12:25 AM
Cannot wait to see the finished product. Got a rough date you'd like it done by or are you not thinking about the timing?
(Edit: wish you could do some 'tall-guy' improvements in my mini, even at 6'3" I find it impossible to go longer than a 1/2 hour without stretching my legs, 6'5" would be interesting!)
Edited by DaveJH, 08 January 2011 - 12:28 AM.
#253
Posted 10 March 2011 - 10:10 PM
#254
Posted 11 March 2011 - 08:56 PM
you do make it a really good and fast mini
i do not whant to know how many dollar is in it allready
good luck whit the project
cheers from holland
#255
Posted 25 April 2011 - 03:16 AM
