I never liked how far to the right the clutch and brake pedals sat when lined up with the standard mini mounts. There was no place to put my foot for the throttle, it had to lean against the tunnel and that was never comfortable. Decided that I might as well move the pedals over to the left.
As you can see, I also went with a floor-mount throttle pedal, and since the throttle cable needs to be pulled and a floor mount pedal exerts the opposite force, I built a mount for the throttle cable and bellcrank arm. I'll probably put another hole or two in the bottom of the bellcrank arm, so I can adjust the throttle leverage ratios. With the pedal depressed it sits about an 1/8th inch off the floor. I welded a cable stop to the assembly as well, so only the cable housing passes through the firewall.
A better picture:
Decided to move the shifter back and up, figured the easiest way to do that was to move the shift rods inside the car. Fairly straight forward. The top plate on that box is rubber mounted to allow some movement, I don't want it popping out of gear.
Decided today to move the seats back and down as well, to gain more leg room and head clearance. A few pictures of where it's going to be:
The motor and front subframe are back on for the moment so I can take that measurement if you still want it, Jeffreypang911. It is close, that much I can tell you.
cptkirk, while the stalks are ugly they will be covered at some point. This seems like a good solution as well:
http://www.turnswitc.../Turnsignal.htm
More updates as they come.
