http://www.gbcarpart.....erlight5.5x12
I like the polished rim - noticeable but not excessive, like the 6" versions. I know from reading forum searches that I might need to trim a bit of metal from the front wheel arches to stop rubbing. What I don't know is:
1. Will these rims work on the standard disk/drum brake configuration on the '92 Sprite? I've got 12" (X5" perhaps?) rims in there now (standard Rover flat, not dished).
2. Will the black plastic "City" arches stretch to cover the slight body modification I'll need to do to allow the new tires to clear the body?
3. In that same vein, I know the 5.5 deep-dish rims will protrude a bit beyond the City arches (forum posts say about 1 CM) but I'm having difficulty imagining what this will look like - does anyone have a picture of the 5.5X12 wheels inside black City arches that they can share?
4. Last - I plan to fit painted Sportpack arches to the car in a year or two... Will the 5.5" wheels be too narrow to properly fill that space when I do? I can go straight to 6X12s if so. I want to avoid the fully-sized 13" wheels because I've been reading about the steering degradation and the excessive wear on the steering components (as mentioned in the Performance Manual).
This is what I have installed right now:
Edited by ImagoX, 24 July 2007 - 03:12 PM.
