Earlier today I had intended doing an oil change and draining the cheap 20W/50 oil I filled it with which was being used temporarily and as a means of flushing the engine until I was ready to fill up with the lovely Duckhams Q Classic 20W/50.
Unfortunately I first noticed all was not well when I spotted a patch of oil beneath the car and as bad luck would have it the area around/beneath the sump plug was wet with oil too.
Strange though because my sump plug hole was heli-coiled several years back after the original threads gave up, but my Mini was laid up for almost 3 years and nothing leaked in that time?
All I did a week or so back was change the oil and so the sump plug was removed and refitted with the correct copper washer and done up as usual. I've only driven it a few miles since, but now it's leaking and I've discovered that it feels like the thread has gone again. It's also strange because it appeared fine after the oil change and it certainly wasn't leaking then.
The company that heli-coiled it fitted an extra long sump plug and I know that the original plug with the magnet on the end doesn't fit properly. Or at least I could never get it to tighten when the washer was used.
But now the extra long sump plug just spins and won't tighten up properly. Well when you turn it you can feel some resistance but then it just spins again and leaving it at the point of resistance isn't enough to prevent the oil leak either.
Anyway I now need to sort it, so should I: -
A: Try using some plumbers tape on the sump plug? Would this help make it tight and safe?
B: Order a tapered sump plug from Mini Spares but be careful not to over tighten as it can crack the sump?
C: Try and get a different sized sump plug from a local motor factors like Halfords?
D: Pay to get it re-heli-coiled, that's if it's actually possible?
E: Get a road tax refund and stop using my Mini for another 3 years?
Okay the last one was a joke, but any advice would be greatly appreciated but you'd think a heli-coil would last much longer than 6 years? Especially since my Mini wasn't used for 3 of those years!
