Crank Pulley Differences between 998 and 1275
24 replies to this topic
#1 Chrome_GT
Chrome_GT
  • 78 posts
Posted 15 July 2007 - 01:12 AM
I recently fitted a 1275 into my 1971 mini 1000. Problem is the larger pulley of the 1275 engine is so damn close to the radiator bracket bolts that they grind on some occasions. Very disgusting noise!!!!
Can I use the pulley of my 998 on the 1275. My guess is the larger pulley was to improve the harmonics of the crank since there is no offcentre mass to improve balance. Read somewhere there is a cushion in the 1275 pulley. Can anyone confirm that they have used a 998 pulley without blowing there crank to bits? Any links or info is greatly appreciated.
My other options are to remove the bracket bolts and machine them down so the heads are smaller. Or replace with button head screws or something along those lines. Anyone else had this problem after doing a conversion. What was your fix?
Note I am running the 998 radiator and therefore have the bracket where the shroud bolts down onto the top of the engine mount with two screws.
Ray
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 15 July 2007 - 04:48 AM
when you do a 1275 conversion one of the things that you have to change is the rad bracket.
dont use the smaller pulley as you may get cooling issues.
sort the problem without working around it.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 July 2007 - 09:35 AM
I assume you're talking about the crank damper ( and not the water pump pully which Miniboo is inferring too )
In which case, basically it should fit (the 1275 one), if it doesn't then there's something wrong with the install...
Which bolts is the damper catching on ? any chance of a pic' ?
#4 Chrome_GT
Chrome_GT
  • 78 posts
Posted 15 July 2007 - 08:11 PM
Definitely the crank pulley (damper) not the pump pulley.
I'll tryto describe it.
The lower end of the radiator bracket bolts downwards to the engine mount. It's kind of an L shape from the front. Then at the top two horizontal bolts attach the bracket to the radiator shroud. The bolts have their heads towards the pulley.
A picture would definitely help so I'll try to get one soon. The most rearward of the two bolts is the one that hits.
#5 minicong
minicong
    Starting My Mini Up
  • 3 posts
  • Local Club: -
Posted 15 July 2007 - 09:03 PM
Ive just done the same conversion to mine and there is plenty of clearence between the pulley and the rad bracket/bolts although ive uprated the rad, the cowling which fits to the mount is the one from the 998. is the alloy part of the mount bolted up correctly?
#6 Chrome_GT
Chrome_GT
  • 78 posts
Posted 16 July 2007 - 07:37 AM
Damn. Ok I'll have another look at myne to try and figure out what is wrong.Tonght I'll remove the radiator and check it out a bit more.
The original 998
http://img145.images...dscf4320lq0.jpg
The 1275 (1312)
http://img145.images...dscf4322rs0.jpg
http://img252.images...dscf4319oz5.jpg
The above picture shows the engine Mount.
From Memory here is the approx location.
White = edge of pulley
Red = Problem Bolt
Yellow = bracket which bolts to the fan cowling
#7 Chrome_GT
Chrome_GT
  • 78 posts
Posted 16 July 2007 - 07:43 AM
[img=http://img207.imageshack.us/img207/882/25244871cd1.th.jpg]
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 July 2007 - 07:44 AM
What are the colours in reference too... but everything looks normal there
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 July 2007 - 08:01 AM
Ahhh... now the next photo appears...
You need to use the 1275 bottom rad bracket with the long horizontal bolt and not the 998 one... I suspect the cowling is different
#10 Chrome_GT
Chrome_GT
  • 78 posts
Posted 16 July 2007 - 08:11 AM
PHOTOS!! :shifty:
Shot with FinePix A120 at 2007-07-16
The mongrel is highlighted below
Borrowed from http://www.oldschool...light=1971 mini
998
#11 Chrome_GT
Chrome_GT
  • 78 posts
Posted 16 July 2007 - 08:15 AM
Yeah I looked into doing that but the cowlings are way too different. Thee radiators differ dimensionally
#12 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 July 2007 - 08:19 AM
I am confused by this. My 1971 1000 now has a large bore motor in it (albeit A+). See pics of my rad bracket:
If you look a the bottom bolt on your gearbox mounting bracket, it appears that it could move a little, pivoting on the top bolt, so that the top of the gearbox bracket is further away from the pulley? You could try slackening the two gearbox bracket bolts, jacking the engine a little on that side and moving the bracket to gain more clearance???
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 July 2007 - 08:20 AM
PHOTOS!! ;D
The lowest bolt in that photo is the one that I was referring to. :shifty:
#14 Chrome_GT
Chrome_GT
  • 78 posts
Posted 16 July 2007 - 08:30 AM
When The grind first appeared that's exactly what I did. I may need to have another go at doing that but even when I had jacked it to it's limit I only gained a mm or so anyway. It's weird though because noone else seems to have this problem from what I've seen. Thanks heaps for going out to take a photo. Must be early morning over there. 830pm here
#15 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 July 2007 - 08:39 AM
I'm not that daft! It's an old photo! :-
We've been working over the phone with someone in Whangerai recently (spelling probably totally wrong) so I'm getting used to the time difference. It's 9:30am here. ;D
Sorry I can't be of more help :shifty:
