Waaaaaaaahhheeeeeeeeeyyyyy!
#76
Posted 06 January 2008 - 10:59 PM
other than that been getting used to how bloody fast it is lol will be bolting it all back up asap and testing it on a trackday i got for crimbo from my young lady cant wait!
what are you going to do about a filter ? i've bought some socks off ebay and i'm going to put some kind of mesh in them to give them shape...
lee
#77
Posted 06 January 2008 - 11:15 PM
been mot'd for a while didnt get on with the trans x diff so i'm having darren do me a quaife in my casing and i've sold the trans x...
lee
Darren supplied me with one and machined the holes to mate up to the injection / throttle body rubbers -I just need to get an airfloe sensor to mount into it.
Good news on your front - you coming up to Bingley?
#78
Posted 07 January 2008 - 11:09 AM
get out and push?
#79
Posted 07 January 2008 - 11:35 AM
what are you doing for reverse?
get out and push?
Get out and push for a few months but pro-motive are working on a reverse gear mechanism that I will up-date to at the right time.
I'm 18 stone - I only have to lean on the mini and it'll move..LOL..
#80
Posted 07 January 2008 - 12:04 PM
get out and push?
I thought i was the only 18 stone mini driver
Edited by riley, 07 January 2008 - 12:06 PM.
#81
Posted 07 January 2008 - 04:36 PM
looks much neater than the webber socks so i got some going spare lol
#82
Posted 10 January 2008 - 11:09 PM
but dont she look sad!
I cant believe the amount of filler dust in and around the engine bay ! it was in the bodyshop for about a month and its almost 1/4 inch thick in places!
shes plastered in it
engine and subframe is out - next stage is working out where all the electrics are going to be modified, taken out and spliced with the yamaha loom.
I could have done more to help tonight but I just seemed to get in johns way, and managed to give myself a brake fluid shampoo fairly early on........
#83
Posted 11 January 2008 - 12:05 AM
lol, 2 days to go u wreckon?
#84
Posted 11 January 2008 - 12:09 AM
#85
Posted 11 January 2008 - 12:41 AM
#86
Posted 11 January 2008 - 04:51 PM
lee
#87
Posted 11 January 2008 - 09:13 PM
the loom is probably the hardest part working out which wires to put into were on the ignition switch... things always take longer than you plan dont worry take you time and do it right lol
lee
Thankyou O great one - I will learn patience. One day maybe
I'm gonna try and take it steady, I had a sudden realisation that I needed to source and sort water temp gauges and sensors, oil temp, oil pressure etc etc and I had a little panic.
2 hours on the interweb and everything is sorted !
special spacer plate for the oil filter on its way with ( electrical ) oil pressure and oil temp sensor fittings inserted, guages for these also on the way from merlin. Digital speedo and tacho also coming from merlin, and sized to fit original binnacle so no chopping up of dash required, a unit to tell you what gear you're in with an LED read-out ( nice and small so not too obtrusive ) and finally an in-line water temperature sensor mounted into a piece of 30mm aluminium tube to splice into the top radiator hose.
the list of other bits to sort / source is getting smaller so I'm a lot happier today.
thanks for the boost
#88
Posted 12 January 2008 - 01:54 PM
the gear indicator is quite usefull i have one and oh my it was a pig to set up lol one tip though try and wire it as close to the sensor (speed i think) as poss and again stick at it i was driving it on stands for ages trying to get it to readhaha fun and games.
#89
Posted 13 January 2008 - 05:21 PM
keep at it! i dont have any readings for oil actually
i'm using the origional R1 clocks in an oval mini dash... it had an oil level indicator but i took that out when i baffled the sump. bit of black tape over the bulb lol
What do you need to do to make the R1 speedo show the right speed?
#90
Posted 13 January 2008 - 05:28 PM
out of interest...
