Fitting a webasto sunroof
16 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 10 July 2007 - 06:45 PM
Hi im after a bit of advice on fitting my Webasto electric sunroof.
Well i think i know how to fit it but im just after a bit of confirmation really.
Im planning to chop the roof back so that the sunroof will fall in to place, like this.
So where i have marked in red line will be where the roof meets the sunroof so that the sunroof would slot down so it lies flat with the roof. But i would have to drill the holes in the roof to do this, so i have marked them in red.
Is this correct?
Once the hole is cut and the holes are drilled for the bolts, would i then put this metal backing plate in place like this but with the roof between the plate and the sunroof?
Is this correct?
If i have got thing right sofar would i just put all the bolts back in place then its done?
The next problem is, how would i fit the headlining?
Would i put push it uner this:
Or if not please could someone tell me how?
Any help would be great :thumbsup:
Edited by Tomf, 10 July 2007 - 06:53 PM.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 July 2007 - 06:58 PM
your is a bit different to the one i fitted to Mrs bungles
there is a topic in the projects section called project sunroof
what i did was to fit the roof to a piece of thick cardboard and once i was happy with the fit used the card as a template to fit the sunroof
its cheaper to get another bit of card than a mini roof if all goes wrong
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 10 July 2007 - 06:59 PM
Good idea. :thumbsup: it came with a huge bit of card, so ill have a go at test fitting it to that :P
#4 chriszxr750
chriszxr750
  • 91 posts
Posted 10 July 2007 - 07:25 PM
you jammy git where you'd get the webasto, i been after one for ages.....
all the ones i found are too small
looks in good nick though.
chris
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 July 2007 - 11:11 PM
I don't know if this site is of any use, but it does show an exploded view of the Webasto Sunroof as fitted to the 1992 Mini British Open Classic LE: -
The Mini British Open Classic Register link
#6 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 July 2007 - 08:16 AM
Thanks :thumbsup:
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 July 2007 - 11:36 AM
One of the Keeping Your Mini Alive books has a feature on fitting this very roof with lots of pictures. I'll have a look for it.
#8 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 July 2007 - 11:48 AM
If you could find that and pass on some of the info to that would be very very helpfull :thumbsup:
#9 GraemeC
GraemeC
  • 7,418 posts
Posted 11 July 2007 - 12:14 PM
Never done this so choose to ignore me if you want!!
However I don't think the bolts/studs go through the roof as doing it the way you ouline would leave the Webasto sitting on the roof rather than in it. I think you're meant to cut the roof to the outside of the bolts/studs so the outer rubber seal sits on the roof and the aluminium plate then sandwiches the Webasto in place.
#10 GraemeC
GraemeC
  • 7,418 posts
Posted 11 July 2007 - 12:18 PM
Just found that it is in KYMA3 and the only holes drilled in the roof are for the front wind deflector section. The aluminium clamps the Webasto to the roof skin, it is not bolted through.
They also show templates in the guide - I guess you don't have these? Maybe see if Webasto could supply them (www.webastohollandia.com or 0121 313 1222)?
#11 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 July 2007 - 02:48 PM
Thank you very much :thumbsup: yea im 99% sure you are right about the bolts not going through the roof otherwise the sunroof seal wouldnt be touching the roof skin so it would leak.
Thanks :P seems prety straight forward now :P Ill have a look on the webasto sit now and see if i can order a template.
#12 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 July 2007 - 04:52 PM
I tried the website and i cant get it to work... also the phone wont dial for me when i called them when i received your post...
#13 GraemeC
GraemeC
  • 7,418 posts
Posted 11 July 2007 - 04:56 PM
They are the details listed in the article, but the mag is a few years old now I suppose.
#14 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 July 2007 - 04:59 PM
OK thanks anyway :thumbsup: ill have a hunt round and try and find some info.
#15 GraemeC
GraemeC
  • 7,418 posts
Posted 11 July 2007 - 05:01 PM
Google is your friend. I found this:
http://www.webasto.c...obile_3016.html
and this:
http://www.open-air-...or/index_en.php
The one listed in KYMA3 is a Stratos 400 and searching through for Rover Mini leads to the Hollandia 400 being an option - I would expect they are one and the same. search through the site and email them.
