reverse light switch
5 replies to this topic
#1 rgo
rgo
  • 33 posts
Posted 06 July 2007 - 10:07 AM
Hi all,
Had the problem with reverse lights not working. Checked the wiring and then climbed under the car
and tried take the reverse light switch off to check the condition ... result was that I broke the thing and
have no reverse light what so ever. :) Will manage without them until the next MOT next autumn but
really should get them working as it's a bit dodgy when backing and no one sees your lights.
Any ideas??
#2 ROCKET
ROCKET
  • 573 posts
Posted 06 July 2007 - 10:21 AM
We got a new switch from a mini show, I think from minimine, it was about £7.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 July 2007 - 11:31 AM
have no reverse light what so ever. Will manage without them until the next MOT next autumn but
It's not an MOT thing anyway...
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 06 July 2007 - 12:01 PM
can you still get the switch out ?
a quick way around this would be to fit a lit switch on the dash some where and manually turn the lights on
#5 m1n1
m1n1
  • 755 posts
  • Local Club: I'm unsociable
Posted 06 July 2007 - 09:40 PM
yep it unscrews. a 5 min fix all in all
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 July 2007 - 05:06 PM
Reversing lights are for you to see by, not for people to see you coming. You shouldn't be reversing if there's anyone driving or walking around who you'd get in the way of. You never have the right of way in reverse. And as above they are not a required lamp, but an optional one which is never inspected or tested. If you choose to fit a dash switch in place of the automatic switch though you must fit a telltale on the dash to light up when the lamps are switched on.
