Respraying the front end of my Coupe...
12 replies to this topic
#1 Jammy
Jammy
  • 25,397 posts
Posted 05 July 2007 - 01:15 PM
Right, I have a Rockworth Powertask air compressor (specs are - 1.5Hp, 6 ltr, 7 CFM and 4.5 free air delivery), I was also given some paint, hardener and lacquer with the car, but from here on in I have no clue as to where I start. I'm not sure even what type of paint I have? I think its 2pac?
The paint tin states that its from Tetrosyl, and says Polyester on it. It apparently contains Xylene and is a pearl paint.
The Standard hardener is 20:32 from U-POL and the lacquer/clear coat is 20:80 and also from U-POL? On the back of the lacquer one of the translations is clear coat 2k, which leads me to believe I'm dealing with 2pak?
Also to mention is that I'll be spraying this outside, hopefully this weekend whilst its nice and sunny/at least dry.
So can I spray this paint using the compressor I have? And which attachments will I need? Whats the correct procedure for prepping and spraying? The front end already has paint and lacquer, but the lacquer has peeled quite badly, hence the respray.
#2 ian
ian
  • 676 posts
Posted 05 July 2007 - 02:38 PM
Jammy, you really could do with a bit bigger tank than 6ltr, it will be constantly running with a tank that small.
your also need a gun if you dont already have one.
as for the paint you have i havent really got a clue, but ive used tetrosyl before with no probs but that was celly paint.
dont take my word for it (someone with more knowledge will come along in a mo) but id of thought you will need to get the old lacquer off if it has started peeling, otherwise whats to stop it peeling after you have done the job.
as for doing it outside, can you not go and buy one of those cheap gazebo things and paint it in there, better that getting dust land on your wet paint.
if you want to borrow a bit bigger compressor and gun you can come and get mine, im near eastbourne though.
#3 midridge2
midridge2
  • 1,794 posts
Posted 05 July 2007 - 04:16 PM
totaly illegal to spray 2k outside, also plan a couple of weeks of work coughing your guts up if you spray 2k without a airfed mask.
#4 Jammy
Jammy
  • 25,397 posts
Posted 05 July 2007 - 04:43 PM
I imagine I'm right in thinking that I have 2k then?
#5 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 05 July 2007 - 06:04 PM
This 'll sound abit silly but what does the paint smell like??
#6 Jammy
Jammy
  • 25,397 posts
Posted 05 July 2007 - 07:03 PM
Ha ha, I can see me smelly this paint, going on a week long bender, then you saying, 'Yup, that'll be 2k!'
#7 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 06 July 2007 - 12:57 PM
Good to see you've refrained from using paint brush and dulux tin.
#8 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 06 July 2007 - 01:16 PM
That compressor is titchy ! If you look at the guns on Machine mart I dont think it meets the CFM needs for them either :)
#9 redhotmini
redhotmini
  • 1,607 posts
Posted 09 July 2007 - 07:37 PM
nothing wrong with dulux and a paintbrush....
if you're painting walls
#10 Jammy
Jammy
  • 25,397 posts
Posted 09 July 2007 - 08:58 PM
Or a Ford Escort! :P
#11 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 11 July 2007 - 11:22 AM
Or a Ford Escort! :thumbsup:
Or some of the front panels on my mini judging by the state of it. (it wasnt me !)
#12 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 13 July 2007 - 12:39 PM
Started spraying yet then Jammy ? :P
#13 Jammy
Jammy
  • 25,397 posts
Posted 13 July 2007 - 12:54 PM
Not yet, I need to find out what parts to mix this paint and lacquer up in!
