TwinK - 98% BMW free
345 replies to this topic
#241 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 13 April 2008 - 11:48 PM
lol i wish i was this close.
#242 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 14 April 2008 - 12:10 AM
Your water outlet pipe from the head appears completely different to mine - but in a good way!
is yours a factory piece or have you made it especially for your electronic pump rig?
thanks
Martin.
#243 Udo
Udo
  • 1,670 posts
Posted 14 April 2008 - 11:48 AM
I made it from scratch but nothing to do with the electric pump just needed it angled different to standard and to hold the ecu temp sender
#244 Udo
Udo
  • 1,670 posts
Posted 16 April 2008 - 06:55 AM
Picked up my header tank last night - alloy one to fit in the weber box, also got the oil return and breathers sorted so just need to plumb in the header tank put in some oil and coolant but one small problem is the charge light on the dash, which I have asked about in the tech section but can't seem to find the problem for. :thumbsup:
Such a minor thing holding me back is very annoying
#245 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 16 April 2008 - 11:58 AM
Looks like your making good progress now mate.
Ive posted on you other thread about the alternators. :thumbsup:
#246 Udo
Udo
  • 1,670 posts
Posted 16 April 2008 - 12:00 PM
Cheers mate I've responded also. Its looking possible for sunday to be on the road - if I can just sort this alternator out
#247 Udo
Udo
  • 1,670 posts
Posted 17 April 2008 - 12:25 PM
All bits and pieces now fitted and fault is the alternator still BUT
turned the key got oil pressure :-
Water pump works :dontgetit:
Electric fan works :genius:
Power from ECU :angel:
Sparks from spark plugs :)
But she wont start >_< not even a hint of trying to fire up like the leads are the wrong way round unless I have them completly and utterly wrong - which is possible
Other possibility is that the alternator isn't working so not giving enough power to the ecu?
#248 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 17 April 2008 - 04:41 PM
ahh thats a shame :thumbsup: how about jump starting it...if a running car supplying 14volts cant start it, the problem has to be somewhere else
is it fueling? if so is fueling set correctly? if not might be so far out its not starting up? see if you can richen up the mixture be easier for a spark to start up a rich mix rather than lean
how you check spark? with a strobe light?, that should surly show you that its sparking at just about tdc (wont determin 360degre out tho)
#249 Udo
Udo
  • 1,670 posts
Posted 17 April 2008 - 04:57 PM
it all set up as it was running in JohnK gold car same ecu map etc etc same fuel pump
Def has a spark (just put new plugs in) def has fuel (could see on old plugs) but not even a hint of wanting to fire
checked all the injectors are firing
checked coil pack connection but its sparking anyway so all is fine
engine is turning over okay but just wont catch
It not jump starting that it needs I dont think as its turning over fine
#250 mini93
mini93
  • 8,615 posts
Posted 17 April 2008 - 09:46 PM
does your ecu have a starndard setting like 10deg BTDC if you unplug bits? not sure it would work...maybe worth a try tho
deffo not sparking on exhaust rather than compression stroke? :thumbsup:
bout out of ideas from me lol
#251 Udo
Udo
  • 1,670 posts
Posted 18 April 2008 - 08:12 AM
Spoke to Simon at SC yesterday evening and he came up with an idea, to do with what mini93 said above, this engine being pre=production bits and pieces he thinks (and I hope) that its basically firing at the wrong point
production ecu's and trigger wheels fire at the 90 degree BTDC as most systems do but the one on the car is timed differently so he is going to flash another ecu and send it to me
Its the only thing he could think of as I have fuel and spark.
I did swap the plug leads over and got a hell of a bang :thumbsup: out the exhaust, neighbours must love me!
#252 Udo
Udo
  • 1,670 posts
Posted 18 April 2008 - 08:13 AM
Oh MOT cancelled, i'll try and book one for tomorow but dont think I'll have much luck
Edited by Udo, 18 April 2008 - 08:14 AM.
#253 matty...
matty...
  • 605 posts
Posted 18 April 2008 - 08:14 AM
Disconnect the injectors and squirt a little easy start in the TB's. If it fires you know you have compression and spark (in the right place).
Have you checked the fuel pressure at the rail yet?
#254 Udo
Udo
  • 1,670 posts
Posted 18 April 2008 - 08:16 AM
I think I'm going to leave it and try the ecu first but thanks anyway
not checked fuel pressure but good idea and I know a man with a gauge - think it should be okay thou
#255 matty...
matty...
  • 605 posts
Posted 18 April 2008 - 08:21 AM
Lol...im to slow at typing, didn't read you other posts! :thumbsup:
