TwinK - 98% BMW free
345 replies to this topic
#196 Udo
Udo
  • 1,670 posts
Posted 11 February 2008 - 12:28 AM
The threaded part is bigger than the shank so wont fit thru the caliper to screw into the hub
#197 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 11 February 2008 - 12:35 AM
ooh yeah :)
#198 Udo
Udo
  • 1,670 posts
Posted 11 February 2008 - 06:32 PM
Think I've sorted out my fuel pump! Should be collecting it saturday so won't need a return fuel pipe yay :ermm:
#199 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 February 2008 - 09:27 PM
let me know what the make and model number is.(mr2?)
#200 Udo
Udo
  • 1,670 posts
Posted 11 February 2008 - 10:02 PM
Celica 2000 reg -someone has kindly put it into ditch so I can get the pump off it :teehee:
Edited by Udo, 11 February 2008 - 10:03 PM.
#201 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 13 February 2008 - 10:14 PM
Ah so you went for the Toyota pump! :thumbsup:
Would you be able to get the part number off your TPS and maybe take some close up shots. Were trying to work out which TPS sensor John used as the standard BMW is a switch type instead of a variable type.
#202 Udo
Udo
  • 1,670 posts
Posted 13 February 2008 - 11:19 PM
Yeah matty, always wantted to try and avoid the return fuel pipe. Just seemed like a neater simple solution, just got to fit it to the tank which I'll see on saturday when i pick it up.
I'll have a look at the TPS part number over the next couple of days. Think its a standard BMW one thou?
Mini is back on 4 wheels tonight, got the coil over top brackets fitted and the coilovers etc, put the wheels on and lowered off the stands, not sorted the brake calipers yet but means I can move it around again.
Delivery from Minispares also turned up today, engine paint, new clutch master cylinder and couple of other bits
Changed the master cylinder but cant bleed it till the engine is in obviously
Painted a few of the small bits and pieces like alternator bracket and stripped down a rod change mechanism to give it a good clean and paint up. Picked it up cheap as my old gearbox was a remote change but it is in a bit of a state. Should soon clean up thou.
Forgot the camera again also!
#203 Udo
Udo
  • 1,670 posts
Posted 14 February 2008 - 06:51 PM
Todays post delivered this -
Sh engineering water pump outlet plate as I have an electric pump
Also one gruby rod change mech to compare to when I've cleaned it up and front suspension all fitted :thumbsup:
#204 miniboo
miniboo
  • 9,327 posts
Posted 14 February 2008 - 07:44 PM
hubba hubba nice water outlet. i am going old scholl and using a normal pump with mine.
#205 mini93
mini93
  • 8,615 posts
Posted 14 February 2008 - 08:21 PM
got piccys of the extra drillings?? just wondering really, looks really nice tho! very nice indeed
#206 Udo
Udo
  • 1,670 posts
Posted 14 February 2008 - 09:52 PM
What do you mean by extra drillings? It fits in place of standard water pump
or do you mean the subframe?
#207 mini93
mini93
  • 8,615 posts
Posted 14 February 2008 - 10:03 PM
yeah :thumbsup: ment subby
#208 matty...
matty...
  • 605 posts
Posted 14 February 2008 - 10:38 PM
Ah cool, your going electric pump too! What pump are you going for just out of interest?
#209 Udo
Udo
  • 1,670 posts
Posted 14 February 2008 - 10:40 PM
Ah right :thumbsup:
Didn't take any pictures but subframe is held in place via the following
2x tower mounts, not standrad thou as the tubular upright fits thru the bulkhead and then there is a nut instead of the bolt.
rear subframe "legs" fit via 4 nuts/bolts to each leg, 2 into the horizontal part of the floor and two into the sloping bulkhead part
across the bulkhead, just under my turbo box are 3 fixings
then behind each tower upright there is a plate with 4 fixings which half of which can be seen just to the left of the coilover in the picture
There are also mounts to carry the front panel again not standard and I still need to work something out for these but shouldnt be a problem
So in total there are 23 fixings to the body for the subframe!!!
#210 Udo
Udo
  • 1,670 posts
Posted 14 February 2008 - 10:44 PM
It came with a davies craig pump and controller so will be running with no thermostat, I know some people have had these fail but its what came with the package so will be going back on.
Also there will be an electric fan and thermostatic controller
