TwinK - 98% BMW free
345 replies to this topic
#181 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 08 February 2008 - 12:02 AM
what can go wrong bolting stuff together, paint drying will take a lil longer qith this stupid temprature, but that should take all weekend, unless you work saturdays or genraly busy anyway
#182 Udo
Udo
  • 1,670 posts
Posted 08 February 2008 - 01:03 AM
Only problem I can see is drilling the extra 2 holes either side for the coilover top mounts
They fit via the 4 standard bolts plus 2 extra at the top of the mount but its right up under the wing or working around the wiper motor one side and the brake master the other but then I'll be trying to drill from the wrong side to use the mount as a guide
EDIT just had a thought about those 90 degree right angle drill attachments - could be worth a try - only 4 holes after all
Edited by Udo, 08 February 2008 - 01:07 AM.
#183 Udo
Udo
  • 1,670 posts
Posted 09 February 2008 - 07:35 PM
Todays progress...
15 holes to drill DONE
unbolt it all to remove subframe againDONE
prime & wait for primer to dryDONE
Paint & wait for paint to dry
Bolt upper coilover mounts in place
Fit coilovers
Fit brake discs and calipers
Fit wheels
Didnt get as much done as I wantted, bought one of those 90 degress drill attachments which then broke after 3 out of the 4 holes I needed it for so had to take it back, wait ages for a refund then go somewhere else and buy their version, why couldnt it break after 4 holes then I could have saved my money :thumbsup:
May nip out later, if I don't go to the pub, and put some body colour paint on
Ian
#184 Udo
Udo
  • 1,670 posts
Posted 10 February 2008 - 11:28 PM
Todays progress...
unbolt it all to remove subframe again DONE
prime & wait for primer to dry DONE
Paint & wait for paint to dry DONE
Fit coilovers
Fit wheels
Didn't bolt upper coilover brackets in place as I decided to tidy them up and repaint them, paint is currently drying so will be in place tomorrow night - which is obviousley why the coilovers are fitted
Drive shafts cleaned up and fittedalong with the brake discs
Brake Calipers - Now here I have a small problem in that the threads in the hubs (force racing Ti ones) are metric and so 10mm where as the holes in my calipers are imperial and so just under 10mm so the bolts won't go thru'
Now do I enlarge the holes in my calipers (standard 8.4's) but then I cant sell them on when I get some alloy 4 pots / cooper S calipers to go under 10's, which I am going to ultimatley do. Basically cheap fix now which will cost me in the long run or another load of money now.
Still going to have to enlarge the new caliper holes whenever I get them anyway.
So until I make up my mind I'm a bit stuck on getting it back on 4 wheels so will concentrate on painting the engine etc. Going to ring a few places tomorrow and place some orders
Decisions to make
Ian
#185 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 10 February 2008 - 11:32 PM
drill them to 10mm you dont normally get much for calipers anyway unless they are recently reconditioned??
#186 Udo
Udo
  • 1,670 posts
Posted 10 February 2008 - 11:37 PM
They were brand spanking new when fitted so still have the gold (zinc?) finish to them - I know what you mean thou only standard calipers after all
#187 mini93
mini93
  • 8,615 posts
Posted 10 February 2008 - 11:45 PM
buy them now :)
#188 Udo
Udo
  • 1,670 posts
Posted 10 February 2008 - 11:50 PM
Easier said than done, money.
I need to investigate which calipers will fit under 10" Dunlop D1's only ones I know will fit are cooper S ones but would really like some 4 pots due to the power that they are going to have to rein in. Plus they are lighter :)
#189 ed4ran
ed4ran
  • 2,849 posts
Posted 10 February 2008 - 11:53 PM
When im back in lincoln you can try putting one on my mini, 7.5" Minispares alloy 4 pots.
#190 mini93
mini93
  • 8,615 posts
Posted 10 February 2008 - 11:55 PM
:) tell me about it, was only joking by the way :P its always nice but never practicle money wise
#191 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 February 2008 - 12:00 AM
ERA turbo caliper bolts is what you need is it not?
i think it has a metric shank and an imperial thread: http://www.minispare....aspx?pid=35377
#192 Tom Booth
Tom Booth
  • 822 posts
  • Local Club: TurboMinis.co.uk
Posted 11 February 2008 - 12:18 AM
Have you had a play with the single pot 7.5's? I'm running them with Mintex uprated pads (Think there M144 or something) on standard discs, and there awsome power.
Cars looking good by the way man, should be a flying machine when its done!
#193 Udo
Udo
  • 1,670 posts
Posted 11 February 2008 - 12:19 AM
ERA turbo caliper bolts is what you is it not?
Yeah but mine are the other way round. imperial shank with metric thread
Cheers Ed that would be very helpful, If you could let me know when you are around I'll pop round with a wheel
#194 Udo
Udo
  • 1,670 posts
Posted 11 February 2008 - 12:22 AM
Cheers for the comments Tom, My mate used to have 7.5's and he thought that when he went to 8.4's they were better, which confuses me a little
#195 mini93
mini93
  • 8,615 posts
Posted 11 February 2008 - 12:23 AM
thought bout getting them made up? go to a bolt specialist shouldnt be much of a problem at all
