Matt's Megajolt guide
#121
Posted 02 June 2008 - 10:31 PM
gonna get megajolt'ed up asap! love how you can set rev limiter and shift light just with the mjlj too.
#122
Posted 03 June 2008 - 09:15 PM
#123
Posted 03 June 2008 - 09:17 PM
#124
Posted 03 June 2008 - 09:30 PM
#125
Posted 09 June 2008 - 07:53 PM
#126
Posted 09 June 2008 - 08:00 PM
As for cars to look for.
MKIII Fiesta, 1.1, 1.3 OHV (loads in the scrappy and the people in the yards don't think they're anything special). The module is mounted on the bulkhead, the coil on the back of the block, the VR sensor on the front. Avoid the ones with ESC written on the module, although the looms off those are handy for a base (a lump of wires) to hack into to mod for the mini loom. Just don't try and use the ESC loom multiplug as it won't fit the EDIS 4 module.
Escort 1.1, 1.3 OHV, early Zetecs (1.4, 1.6, 1.8 IIRC).
Focus, Mondeo, 1.6, 1.8 Zetec and 2.0 Duratec doodah engine too.
Basically, anything with a coil module and an EDIS 4 module. I believe the autosport labs site has a list of vehicles that are suitable donors, but I'd deffo be looking out for '92-'95 Festers as they're a nice easy hack (actually, the coil's a bugger to get to on them).
The later Zetecs (like my GF's 99 Focus) have the coilpack mounted on the N/S end of the head, with a nice bracket that's held on with three bolts (T30 or T25 head I think).
Hope that helps a little
#127
Posted 09 June 2008 - 08:03 PM
VR sensor (Magnetti Marelli SEN8D to suit SC and KAD mount/trigger kit): £15ish
Coilpack (new non-Ford) £15-35 depending on motor factors and how well you know the geezer behind the counter!
In some cases, it's worth using second hand to get setup, then replacing with new parts as and when you can afford to!
#128
Posted 09 June 2008 - 08:05 PM
If there any cars the HT leads can be used off? or do you defonately have to have them custom made?
#129
Posted 09 June 2008 - 08:08 PM
Go for OHV Fiesta ones, I used the kit initially, then decided to get some 8mm ones from Halfords that were designed for the Fiesta. It depends on where you mount your coilpack, but the Fiesta ones are a little long for some installs.
#130
Posted 09 June 2008 - 08:15 PM
this may seem like a stupid question but a what in what line i'm just in the proces of doing this myselfdid you not put a reservoir in the vacuum line? autosport recommed it for a propper reading.
#131
Posted 09 June 2008 - 08:21 PM
hope this helps, but only one weber obviously, gives you a constant less bumpy reading, hard to get a smooth reading without the res because the valves are opening and closing so the vacuum is far from constant.
if you wondering what the vacuums for its to tell the megajolt unit what load the engine is under so it can advance / retard the ignition
al
Edited by alexcrosse, 09 June 2008 - 08:22 PM.
#132
Posted 09 June 2008 - 08:27 PM
this doesn't count for SU's only webbers?
****end of stupid questions hopefully****
#133
Posted 09 June 2008 - 08:38 PM
as matt describes as 'pulsey'.
#134
Posted 11 June 2008 - 09:05 AM
For those tapping into steel weber manifolds, do you weld in your take-off? or drill/tap and screw in some take offs?
#135
Posted 11 June 2008 - 09:15 AM
Just to point out, that KADs trigger wheel kit includes the sensor too. Both KADs kit and SC trigger wheel kit have clearance problems with the fan belt though!
