Matt's Megajolt guide
261 replies to this topic
#76 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2007 - 08:23 PM
What trigger wheel have you used with the machined damper.
#77 Ethel
  • 25,923 posts
Posted 12 July 2007 - 10:10 PM
Is that aimed at anyone in particular Tom?
The 5.125" trigger wheels one with the 4" centre is the easiest
you can also pull one off a Ford CVH.
#78 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2007 - 10:13 PM
Thanks :P ill look for a CVH engine at the scrappy ;)
#79 Phaeton
Phaeton
  • 1,055 posts
Posted 12 July 2007 - 10:14 PM
Assuming it aimed at me it's a 5.125" from triggerwheels.co.uk or com can't remember.
Alan...
#80 Ethel
  • 25,923 posts
Posted 12 July 2007 - 10:23 PM
You have to machine the CVH wheel as well as the pulley so unless you've got access to free machining the Trigger wheels pulley may be a cheaper option.
#81 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2007 - 10:29 PM
What machine work is needs to be done to the CVH wheel? well me school tutor lets me use any machines i need to use so i have access to any machines the school has...
#82 Ethel
  • 25,923 posts
Posted 12 July 2007 - 10:38 PM
you should be ok then - believe you just have to cut back the centre so it fits on the outer of the Mini damper - a lathe with a moderate sized chuck should be up to the job. Theres some info and tech drawinds on minfinity I think.
It looks really good when done
#83 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 12 July 2007 - 11:02 PM
Thanks :P ill have a look on finity and see what i can work out ;)
#84 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 13 July 2007 - 09:43 PM
got my megajolt kit today. started soldering it together. soooo easy to do. broken my multi meter though so need to go and get a new one before testing the voltages.
might put up a seperate post in the "other projects section" on how to put it together, although it will be very similar to the autolabs site.
#85 Ethel
  • 25,923 posts
Posted 14 July 2007 - 04:31 PM
This seems to be the spot for all matters megajolt now...
Just got my Trigger Wheels trigger wheel, looks very serviceable and only weights 125g grams. Ask me if you'd like pictures and a write up on it's installation - there's already a fair bit of info online.
Also got a letter from Parcel Force saying they're holding my self assembly kit from the US of A to ransom! £10.27 for vat is fairy muff I suppose but £13.50 for collecting it for the chancellor seems a bit steep, no wonder they're making a huge profit again. Worth bearing in mind if you decide to order direct as well.
I've bought loads from China off Fleabay and this is the first time I've had this >_<
#86 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 14 July 2007 - 04:40 PM
oh can i see some pictures of the trigger wheel?
#87 smudger
smudger
  • 1,854 posts
  • Local Club: Lots
Posted 14 July 2007 - 07:23 PM
the more info and pics the better, since each person will have a different way of doing it.
and people wonder why we want to sort it as a present......................
#88 miniboo
miniboo
  • 9,327 posts
Posted 14 July 2007 - 08:05 PM
what size I.D. pipe did you use for the connection from the manifold to the Megajolt MAP sensor connection?
#89 Ethel
  • 25,923 posts
Posted 14 July 2007 - 08:17 PM
Miniboo,
If that was aimed at me I haven't even got my Megajolt yet!
I'd think small is good - the same as the jolt's connector?
Check out Drallim.com for ideas
#90 miniboo
miniboo
  • 9,327 posts
Posted 14 July 2007 - 08:19 PM
Sorry was aimed at minimadme.
took me about 2 hours if that to solder the kit together.
that includes having to go out and buy a new soldering iron aswell. think i might start doing these kits myself and selling them!!
