Matt's Megajolt guide
#31
Posted 02 July 2007 - 09:33 AM
#32
Posted 02 July 2007 - 09:43 AM
#33
Posted 03 July 2007 - 02:34 AM
Would you be bale to get it on with a fully built engine bay? or is it an engine out job? Rad out?
#34
Posted 03 July 2007 - 06:33 AM
how easy is it to mount the trigger wheel?
Ummm, nah you could do it with the engine and rad in place.
Basically, set engine to TDC, go through the inner wing with a socket and extension (by the brake pipe union, under the radiator) undo the crank bolt, leave the pulley in place. Put the trigger wheel adapter and new bolt in place and tighten it up. You then place the trigger wheel on to the adaptor, which is then held in place by a threaded ring (C-spanner is used to tighten it up).
Then, once you've mounted the trigger wheel, you can mount the sensor bracket onto the timing cover (you'll need a couple of longer bolts to go through the bracket and the two timing cover holes). Then, once the sensor is mounted, you can adjust the position of the trigger wheel in relation to the sensor (set the engine at TDC, then the sensor needs to be 90 degrees before the missing tooth in the pulley).
#35
Posted 08 July 2007 - 03:34 PM
#36
Posted 08 July 2007 - 03:39 PM
#37
Posted 08 July 2007 - 03:50 PM
#38
Posted 08 July 2007 - 03:56 PM
Might splash the cash and spend $15 inc postage!
#39
Posted 08 July 2007 - 04:02 PM
#40
Posted 08 July 2007 - 04:03 PM
removing number 1 spark plug
remove dizzy cover, turn engine over by hand till rotor arm is pointing at number 1 lead
put piece of wire or thin screw driver in plug hole and by rotating engine both ways you will see your screwdriver just begin to drop
turn back a touch and this is TDC
I have never done this on a Mini but it has worked on other cars I have owned. No doubt their is a more scientific way to do it that will be explained later!
Hope it helps.
EDIT: Damn you mini93.
Edited by gavfoz, 08 July 2007 - 04:05 PM.
#41
Posted 08 July 2007 - 04:07 PM
I cant wait to get this all installed now
#42
As for the other components I simply took them of of the various fords, my greatest moment was cutting out a whole EDIS loom from a car (an orion I think), basically I traced the connections back until they had a common focal point (where it goes into the car to the ECU) and cut the whole lot out, that means that I didn't have to split any wires or solder bits in to make lengths and Ford had done all the hard bits. All I did was break open the loom and snip out any wires I didn't need, then recover in tape to give shape and protection. Total cost £5! Also it fits the mini engine bay perfectly to run wires out of sight.
As for the trigger wheels again mine cost £5 (trigger wheel of a sierra) and half an hour getting my friend to weld it together (on a mini pulley)
that seems easy enough to follow.
#43
Posted 08 July 2007 - 04:08 PM
#44
As for a shift light. The MJLJR has an output for a shiftlight anyway, so you basically need to just wire that up to a small 12v bulb fitted to your dash and hey presto.
As for fitting one to someone elses car, I'd rather get mine working 100% first!
I am working on the idea of supplying a full fitting kit, which would include machined pulley, bespoke VR sensor bracket, bespoke coil bracket and so on. I've only thought of this because nobody else offers a comprehensive kit at the moment.
#45
Posted 08 July 2007 - 04:16 PM
however, the cost of the above begins to make it expensive.
maybe just the pulley, bracket, dizzy plug and tapped inlet?
just leaves the edis system, connectors and leads then. (or maybe more)
if that was all avaible from the one place, then you could basket what you want and what you want to find.
if you do go that route, i am intrested in the pulley, inlet, bracket and dizzy plug.
Bing (2)
