Matt's Megajolt guide
261 replies to this topic
#211 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 06 January 2009 - 08:40 PM
Very good guide matt!!
A question about the trigger wheel etc.
Iv got my pulley off and ordered the trigger wheel tonight, then going to get it machined and fitted...
Have i read right that the trigger wheel goes 90degrees before TDC?
Then can the sensor go anywhere, or where??
cheers.
Edited by screech, 06 January 2009 - 08:41 PM.
#212 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 06 January 2009 - 08:49 PM
The missing tooth goes at TDC
The sensor is fitted at 90degs before TDC.
I think thats right, cant remember doing mine lol
#213 screech
screech
  • 3,136 posts
Posted 06 January 2009 - 09:17 PM
Ok, so when number 1 is at TDC, the missing tooth should be at the top tooth of the teeth on the timing cover??
And it may be a silly question, but at TDC should it be the centre of the missing tooth, beginning or end of???
cheers
#214 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 06 January 2009 - 10:03 PM
middle, but to be honest it doesn't have to be that accurate. You can fine tune it with the software ;D
#215 screech
screech
  • 3,136 posts
Posted 06 January 2009 - 10:16 PM
Ok that great cheers... and last for now... how far from the trigger wheel should the sensor be? that has to be spot on doesnt it?
cheers
#216 Ethel
  • 26,061 posts
Posted 07 January 2009 - 12:03 AM
You can put the sensor anywhere, the edis assumes tdc is 90 degrees after the missing tooth has passed it so, ideally, make sure when the engine is at tdc the gap is 90 degs after the sensor. You can just correct it with the software but edis has a limp home mode so you will need to be pretty near to make use of that if you want to. The pick up to wheel clearance specified is 1mm.
If you haven't already have a look at http://www.autosportlabs.net/Main_Page
#217 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 09 January 2009 - 09:20 AM
http://www.autosport...cal_information
#218 screech
screech
  • 3,136 posts
Posted 16 January 2009 - 05:33 PM
Got my EDIS bits today, had a good look at them and over some diagrams on line, but cant really make much of them.
Anyone fancy telling me what wire is what? :D
cheers
#219 Ken555
Ken555
  • 60 posts
Posted 16 January 2009 - 06:00 PM
Try this page
#220 screech
screech
  • 3,136 posts
Posted 17 January 2009 - 08:59 AM
Thats a great help, thanks.
On the picture above you can see on my sheilded cables, the sheild goes into the connector, then comes back out again, as to go along with the cable, where does this go??
And where does the other wnd of the sheild go?
cheers.
#221 atom
atom
  • 239 posts
Posted 17 January 2009 - 10:16 AM
Pins 1 and 2 (blue/yellow and blue/red) simply go into the MegaJolt unit itself, as PIP and SAW. Pin 4 (brown) connects to the cable shield of these two.
The shield only connects at the EDIS end - at the MegaJolt, only PIP and SAW connect.
The diagram on the page that Ken linked to is exactly how I conntected my MJ unit up.
#222 screech
screech
  • 3,136 posts
Posted 19 January 2009 - 09:54 PM
thats great, cheers.
Does the pip and saw really need a sheild if the edis unit and megajold are mounted quite close to each other behind the dash??
cheers
#223 Ken555
Ken555
  • 60 posts
Posted 20 January 2009 - 10:03 AM
I would still do it.
I have seen Fords without the shielding, but better to spend a few pence on the cable, rather than have problems.
#224 screech
screech
  • 3,136 posts
Posted 02 February 2009 - 04:02 PM
Will a 15A supply be ok for the MJ and EDIS units?
cheers
#225 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 20 February 2009 - 08:42 PM
today, after a first restart of my engine last week end I decided to got out with the car. At the beginning, all was great.
I decided to stop the car in order to check and adjust my carbies (2 weber 40 mm DCOE). Then I restarted the engine and few meters after, i lost power.
I check all the grounds. But nothing especially to notice. I succed to restart the engine with the defaut advance from the edis (not easy with my VR).
I plugged my lap top to the megajolt. I take note there is no map on this one.
Ok, i rewrote mine, and calibrate my TPS. I just restarted the engine for a quick test. It seemed to be ok.
But i can't have enought time tonight to go out for a new run.
How can you explain what happened ? I check up my fuzz. It is ok.
No problem of communication betwen my lap top and megajolt. Have you any ideas ?
thanks for help before new test and run tomorow !
