Matt's Megajolt guide
261 replies to this topic
#181 Retro_10s
Retro_10s
    Moderator
  • 10,187 posts
Posted 24 November 2008 - 05:46 PM
hmmmm now i'm planning building a special 998 up and at first considered Megajolt to be a Mega pain in the arse.
But I've just sat and read through the whole thread,.. it's not so scary after all >_<
I believe i might come across the same problem that Ethel did, as I have a Belt drive kit to replace the Timing chain.
#182 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 05 December 2008 - 03:35 PM
hi
about the tacho of the dashboard. What we can do on the wiring in order to read rpm on classic tacho.
V4 spec.
thanks for advice and tipes
#183 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 05 December 2008 - 07:40 PM
You should be able to use the output on the back of the Megajolt for your tacho (rev counter). There is a picture on the first page of this thread.
#184 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 05 December 2008 - 08:29 PM
you fit your wiring lom used forthe original coil (-) directly on this output and nothing else ? on the megajolt forum, they talk about problem to use their tacho. Did you refit your own tacho like you advice and nothing else ... i use the nippon tacho and gauge from last mini '90 's
#185 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 07 December 2008 - 11:49 AM
up
#186 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 07 December 2008 - 02:53 PM
I ran a fresh wire from the output on the Megajolt to the back of my dash, then ran another fresh +ve wire into the tacho with a 5A fuse inline IIRC.
But I guess that's the same as using the original -ve coil wire that goes to the tacho really.
#187 Ethel
  • 26,791 posts
Posted 07 December 2008 - 03:21 PM
Belt kit made it easier for me if anything - depends where you're planning on putting the tooth wheel, as long as it's not between the fanbelt pulley and engine you'll be fine.
#188 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 07 December 2008 - 07:41 PM
could you fit the white and black wire from the original coil to the rev counter gauge of the edis in order to got rpm on original 3 clocks ?
#189 danboy
danboy
  • 132 posts
Posted 08 December 2008 - 02:30 PM
ive got a mini that had a megajolt v4 already fitted ..but it has no lead to conect to me lap top....where would i get one...thanx
#190 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 08 December 2008 - 06:01 PM
Yes it should work. if not try taking the feed form the pip signal.
Read this: http://www.autosport...Out_on_the_MJLJ
#191 miniboo
miniboo
  • 9,327 posts
Posted 08 December 2008 - 06:02 PM
try this: http://www.autosport...-mjlj-p-43.html
#192 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 09 December 2008 - 04:58 PM
about the shift light, i wish to know what you think about a led buld of 5 w like we can find on this web site (for the V4)
http://www.superbrig...brake-turn.html
#193 Ethel
  • 26,791 posts
Posted 09 December 2008 - 05:17 PM
Not sure the MJ will put out enough current to drive all of those bulbs - spec's on line
#194 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 09 December 2008 - 08:01 PM
I gues you could drive it through a suitable relay though?
#195 seb79
seb79
  • 66 posts
  • Local Club: bmc
Posted 09 December 2008 - 08:25 PM
I (amper) = P (watts) / U (volts)
so 5 watts / 12 = 0,416 A
or 21 / 12 = 1,75 A so without resistance, it 's not usuable
For a 5 watts bulbs with leds, we got 0,416 A enought for a shift light ?
the shift light output, can drive 500 mA.
As fas as I'm concerned, this kind of led bulb could be great ! a realy for this you believe ?
