Matt's Megajolt guide
#151
Posted 13 June 2008 - 08:44 AM
#152
Posted 13 June 2008 - 02:09 PM
Just do a google for MegaTune.
I assume that will work with Megajolt also? it says it for Megasquirt.
#153
Posted 13 June 2008 - 03:08 PM
#154
Posted 20 June 2008 - 09:00 AM
Am i right in saying MAP you dont need the trigger wheel and sensor? Hope not as id much rather just run the vacuum setup.
Edited by BOLDY, 20 June 2008 - 09:00 AM.
#155
Posted 20 June 2008 - 10:21 AM
#156
Posted 20 June 2008 - 05:32 PM
And best of all, it seems to have gotten through customs with no extra charges.
#157
Posted 21 June 2008 - 11:57 AM
#158
Posted 21 June 2008 - 03:50 PM
#159
Posted 21 June 2008 - 05:15 PM
I have read through this topic a couple of times now and just for dummies like me need to clear up a few things.
My engine has a 296 scatter cam so for me a TPS will be best as it is a bit of a wild cam.
I need to take, from the correct ford, a EDIS pack, which consists of Throttle Position sensor, leads, coil. Is this right?
Also I need to get a trigger wheel and bracket for sensor, from specialist components.
To fit the trigger wheel, i need to put engine in TDC, and put the notch in wheel 90 degrees clockwise from top of pulley? To turn by hand, I need to take off engine casing??
What/where is the best megajolt unit to get, can do soldering so what website can i get the kit from?
Thanks for your help,
Jon
#160
Posted 21 June 2008 - 06:34 PM
296 should be okay with MAP i would say. Its when you get to the 310 area when its a bit too mad, just shove a big reservoir on it.
#161
Posted 21 June 2008 - 07:57 PM
#162
Posted 22 June 2008 - 10:36 PM
#163
Posted 23 June 2008 - 02:32 AM
#164
Posted 23 June 2008 - 08:17 AM
so if i get a MED pully with the teeth ready machined... then that means all i have to position is the VR sensor???
#165
Posted 23 June 2008 - 08:40 AM
Hi,Hi All,
Jon
I'm using a 286 scatter with MAP sensor rather than TPS and it seems fine. Didn't run it for long though.
The EDIS pack consists of the coil pack and the ignition module, no throttle position sensor.
You'll need to get the crank sensor with which ever trigger wheel kit you decide to go for, this crank sensor then wires into the EDIS ignition module.
