Swift GTI mini gearbox
#241
Posted 11 January 2008 - 05:33 PM
is it a gti engine uve got??
scott
#242
Posted 11 January 2008 - 05:36 PM
Once I get the bits sorted it shouldn't be hard to produce more.
Dont really need money, its just getting the bits made takes time, mainly as im waiting on others.
Ed.
#243
Posted 13 March 2008 - 02:56 PM
Just mainly all needed to get the gearbox mated and working. The rest pipes etc i can fabricate myself.
How soon do you think till you have something solid that you would be able to produce do you think?? If thats your plan
#244
Posted 13 March 2008 - 04:46 PM
partly as i now live in a flat where there isnt much room let alone a garage i can work on car bits.
How ever i am looking at houses and failing that i am also looking for garages to rent or buy.
I am also looking at getting more tools to do more myself.
So overall i have a lot of possible delays, as well as alot of plans.
If all went well i would plan on having something around summer time (cant promise anything though)
all depends on how work goes and if i can get somewhere to work on it here.
Will update when things start moving again.
I am still looking at the project, and do plan on making more if people are interested,
I'm just not making much progress.
Ed.
#245
Posted 20 April 2008 - 03:51 PM
I think that sums it up
I got the drawings
Finally got round to contacting the guy again and asked if he could send me what he had, although think he is looking for digital versions.
Ed
#246
Posted 20 April 2008 - 04:23 PM
BM
#247
Posted 06 May 2008 - 12:43 AM
#248
Posted 06 May 2008 - 01:08 AM
I didn't think 'leccy motors needed a gearbox either?
#249
Posted 06 May 2008 - 05:28 PM
#250
Posted 06 May 2008 - 07:39 PM
#251
Posted 15 May 2008 - 06:58 PM
Not really done much apart from changing to better bolts for the bottom of the engine and make flanges etc fit a bit better (helped by the bolts) still trimming to do on the flanges but not going to do anything like that until i actully come to getting them fitted in place.
Anyway a big thanks to Kev (SwiftMini)
Just need to get it bolted on some how and check its alignment, then i need a 1275 mini primary gear (only have 998s
#252
Posted 15 May 2008 - 07:22 PM
#253
Posted 16 May 2008 - 11:54 AM
but im not against selling just the ends, once i can get them made, once im happy with the final design.
#254
Posted 16 May 2008 - 12:19 PM
You can do direct drive but its more effecient to use the gearbox and be able to shift gears. You don't need the clutch as I understand it because electric motors do not have power if you let off the throttle. You lift of the throttle and then shift and then reapply throttle just takes longer to shift and you can't power shift. Sorry off topic. I was looking at this as a way to seal off the gearbox to contain its own oil and mate the motor to the gearbox. If it can be mated to a suzuki engine then it gives me hope.
Really shouldn't hijack Ed's thread but...
The gearbox's input needs to have no load very little inertia so that the synchros can match it to the output side being driven by the road wheels. I think that means a clutch, but some very clever electrics could set motor speed to match.
#255
Posted 16 May 2008 - 12:27 PM
