Cylinder head crack
15 replies to this topic
#1 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 04:38 PM
Is this usable?
hairline crack between the cylinders.
#2 millermilla
millermilla
  • 452 posts
  • Local Club: BMC Brighton Mini Club
Posted 29 May 2007 - 04:42 PM
just out of interest is that a turbo head?
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 04:43 PM
no. a slighty modified 12g940
#4 Road Runner
Road Runner
  • 445 posts
  • Local Club: BMC
Posted 29 May 2007 - 05:04 PM
I would not use it your better off getting another one
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 05:07 PM
will a skim not take it out or anything?
The guy who owns it had it on his 1330cc and it went great. He only noticed it on removal.
#6 Lt-SilverDragon
Lt-SilverDragon
  • 724 posts
Posted 29 May 2007 - 05:30 PM
Think if you can find a decent welder then they'll be able weld it for you.
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 05:34 PM
Mmmmm. I was hoping a skim would get rid of it. Doesnt look likely.
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 29 May 2007 - 05:38 PM
A skim may remove it, but it obviously depends how deep it goes. Depends if you can afford to get it skimmed to find out. Plus, how much can you afford to lose off it CR wise? You measured the chambers?
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 05:39 PM
I havent got it yet, just got the photo.
Edited by Jordie, 29 May 2007 - 05:41 PM.
#10 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 29 May 2007 - 05:40 PM
If it was fine before he took it off, it may still be fine. You never know, if its just a hairline crack the carbon may clog it back up - as im sure it probly was before. You should be able to get it repaired tho. I'd say it'd be much more economical to have it repaired too, rather than bin it. The time that goes into a well modified head it horrendous, not to mention the cost of buying a modified head, and i'm sure the cost of repairing it will be nowhere near the cost of a new one.
#11 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 05:41 PM
its a stg2/stg3 modified unleaded head, so i was hoping it would be repairable.
#12 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 29 May 2007 - 05:55 PM
Thwe problem with cracks is that they tend to get bigger with age, i doubt very much that a skim will remove it. Also remember where this crack is, there is the coolant jacket right above it.
that head is fit for the bin, use it at your risk, its only a matter of time
#13 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 May 2007 - 05:59 PM
Thanks for the input. Ive sent photos off to my local engine services place to see what they say and a estimated cost for repair.
If it turns out to be too much, I will leave it.
#14 blacktulip
blacktulip
  • 6,224 posts
Posted 29 May 2007 - 06:30 PM
did jammy tell u that? :P
#15 Sprocket
Sprocket
  • 7,266 posts
Posted 29 May 2007 - 08:55 PM
Theres always some one who degrades a topic :P :teehee:
