Steering wheel Vibration
19 replies to this topic
#16 bluffin
bluffin
  • 234 posts
Posted 09 June 2007 - 05:45 PM
Does it vibrate whilst the car's stationary when you rev it? or when its moving or under breaking?
very slight vibration at Idle when not in gear but that is normal Mini I think........ no vibration under braking, did think it could be the discs warped but no vibration under braking will rule that out I guess.......
not really sure if I rev it out of gear I will have to try and see
Answers is yes the steering wheel does vibrate when I rev the car
Think it could be the poly bushes??
I have now decided that the vibration is directly linked to engine revs so it must be the poly bushes I have fitted, been looking on the Mini Spares site for a week now but the rubber upgrade bushes they do are always out of stock, does anyone know of an alternative supplier of a decent rubber bush?
#17 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 09 June 2007 - 05:49 PM
Id be considering putting a piece of rubber in the bolt mount to the lower dash rail, to absorb the vibration.
#18 bluffin
bluffin
  • 234 posts
Posted 11 June 2007 - 05:00 PM
Did think about that, but wasn't sure if it would be a bit cowboy
#19 bluffin
bluffin
  • 234 posts
Posted 12 June 2007 - 05:03 AM
o.k how do I get those security bolts undone?
#20 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 12 June 2007 - 08:59 AM
With difficulty ! Either file two flats on it so you can get a spanner/molegrips on it or hacksaw a slot in the end so you can use a big screwdriver.
