Steering wheel Vibration
19 replies to this topic
#1 bluffin
bluffin
  • 234 posts
Posted 26 May 2007 - 05:42 PM
This is now getting on my tits or as the misses would say it's doing my swede in.......
I have just finished putting my mini together it now been on the road 2 weeks ofter passing it's MOT.
I have used new poly bushes kit, with standard subframe and engine mounts and it really feels like the engine vibration is tracing it's way back through the steering wheel, well thats how best to explain it.
I am quite certain it's not the Wheels and Tyres as I have had 2 sets on the car now and I have the same symptoms with both, the car is basically new apart from the steering rack and wheel bearings but not convinced it can be them but it could....... I have also fitted on an ultimate engine steady, wondering if I have stiffened the car up to much and the steering wheel is the only place left for the vibration to go :blink:
Just wondering if I have missed anything obvious, as I am fed up with getting pins and needles everytime I drive the car.
by the way it seems worse with the 165/60/12 as opposed to standard 145/70/12
so to sum up HELP!!!
#2 stef
stef
  • 799 posts
Posted 26 May 2007 - 05:49 PM
is it vibrating constantly? or when? worse at idle/under load? worse or better with more revs?
#3 stefaz
stefaz
  • 202 posts
  • Local Club: Potts About Minis
Posted 26 May 2007 - 05:50 PM
beat me to it stef. was just going to ask that
#4 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 26 May 2007 - 06:00 PM
Are the bushes in the steering column new? when they wear they can cause the steering wheel to vibrate.
Daniel
#5 bluffin
bluffin
  • 234 posts
Posted 26 May 2007 - 07:04 PM
Seems to be better at idle and gets worse with more revs, I would say yes it is vibrating constantly
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 26 May 2007 - 07:06 PM
Are the steering rack 'U' bolts tight?
Lift the carpet, check the nuts. 2 either side.
#7 bluffin
bluffin
  • 234 posts
Posted 26 May 2007 - 07:07 PM
Daniel
hmm no they are not, best I go to mini spare website to buy some.
Any more Ideas?
#8 bluffin
bluffin
  • 234 posts
Posted 26 May 2007 - 07:17 PM
yep they where tight, just checked them they are even tighter now :blink:
#9 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 26 May 2007 - 09:06 PM
Daniel
Any more Ideas?
A way to check if its the column bushes or not is to see if you can move the steering wheel and inner column up and down whilst the outer column stay still.
Daniel
#10 bluffin
bluffin
  • 234 posts
Posted 26 May 2007 - 09:12 PM
Daniel
Any more Ideas?
Daniel
Yeah tried that earlier, steering column seems tight.
Think this is going to be a difficult one to sort :blink:
#11 blacktulip
blacktulip
  • 6,224 posts
Posted 27 May 2007 - 11:11 AM
Daniel
Any more Ideas?
Daniel
Think this is going to be a difficult one to sort :lol:
what about the tracking? track rod ends? balljoints?are they all in line and firm?
#12 Jimi30
Jimi30
  • 138 posts
  • Local Club: Central Minis
Posted 27 May 2007 - 12:23 PM
Does it vibrate whilst the car's stationary when you rev it? or when its moving or under breaking?
#13 bluffin
bluffin
  • 234 posts
Posted 27 May 2007 - 08:11 PM
[/quote]
[/quote]
Tracking was done last week, track rod ends are new as are the ball joints. I really wish it was that simple :lol:
#14 bluffin
bluffin
  • 234 posts
Posted 27 May 2007 - 08:14 PM
very slight vibration at Idle when not in gear but that is normal Mini I think........ no vibration under braking, did think it could be the discs warped but no vibration under braking will rule that out I guess.......
not really sure if I rev it out of gear I will have to try and see
Edited by bluffin, 27 May 2007 - 08:14 PM.
#15 bluffin
bluffin
  • 234 posts
Posted 28 May 2007 - 02:41 PM
Answers is yes the steering wheel does vibrate when I rev the car
Think it could be the poly bushes??
