As I'm driving, once I get over 4000RPM, the needle on my rev counter begins to bounce wildly from 4-5K and I can't get a solid reading... any explanations for a bouncy tach?
Smiths gauges, 1983 mini with a 1275 three main clocks behind steering wheel and three small clocks in the center
Bouncing Tachometer (rev counter)
J-Lo
, May 22 2007 01:20 AM
6 replies to this topic
Posted 22 May 2007 - 01:20 AM
Posted 22 May 2007 - 07:16 AM
Is the engine running OK? A bouncy rev counter can be caused by a dodgy ignition coil, or a loose connection on the coil. But you would get a misfire as well.
Posted 22 May 2007 - 08:01 AM
Mine turned out to be the connections on the coil being loose. So there's somewhere to check.
Posted 22 May 2007 - 08:07 AM
ive had the same prob with mine and everyone said coil. i got lumination so that might be it or even if the car is off and i tap the tacho it bounces, not sure if its suposed to do that??? still gotta try changing the coil tho. ill try it tonight see if i get a result, and let you know.
Posted 22 May 2007 - 10:02 PM
my mate had the wrong coil so couldnt try it. sorry. im gone till monday so i wont be ne help soon. good luck lemme know if you get it sorted plz.
Posted 24 May 2007 - 06:52 PM
Thanks for the info guys... I'll check all of those things either today or over the holiday weekend (it's Memorial Day weekend here in the 'States)
the engine seems to me running fine except for two issues... I have a tad bit of run-on when I shut down sometimes... and when I'm driving at a high rate of speed for a while on a highway, as I exit the highway and I depress the clutch to change gears, the RPMs drop off and the motor stalls... but only if I've been driving steady at 4K RPMS for a bit (15minutes or so)
Edited by J-Lo, 24 May 2007 - 06:56 PM.
Posted 25 May 2007 - 08:01 AM
i've had run on for a little while now and one of my fuses kept blowing. I've changed the coil and it seems to have sorted both problems out !!!
