1) Remote shifter rear mount is different but that will be sorted.
2) I have a leak!! The only leak on the whole engine is coming from the timing cover oil seal. I had the cover off while it was out of the car - i should have replaced the seal! damn.
So- Can the timing cover be removed while the engine is in the car. It looks to me like there isn't enough room to slide the pulley out. Anyone done this?
3) Overheating problems - What can actually go wrong in a cooling system that would cause overheating?
All i can think of is
blocked radiator
block water jackets
wrong or stuffed thermostat
leaks
water pump
or other things like bad timing or lean fuel mixture
I'm tempted to just buy a new radiator from trademe, they are $200 but at least i know for sure that isn't the problem. Probably bout time i got one anyway.
_________________
Edited by Chrome_GT, 21 May 2007 - 07:00 AM.
